3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
More Aesthetic Hard Drive Speaker
A way to make a speaker out of a hard drive that actually looks really elegant. Video included.
I think the original 'hard drive speaker' idea came from Afrotech a couple years ago:
http://www.afrotechmods.com/cheap/hdspeakers/hdspeakers.htm
Step 1Open the Hard Drive
Open the Hard Drive
If your hard drive is held together by torx screws instead of normal screws, and you don't have a torx wrench, use a drill press to drill into the screw heads (this is what I had to do) until everything comes loose.
You'll end up seeing something like this.
Use a hacksaw to cut as far as you can between the hard drive arms and the platters. Then for the final bit of metal under the arms, use a dremel from the backside of the case. Don't worry about cutting through the flexible cable going to the arms, you should be able to see where the arm voice coil (the coil of copper wire between the two magnets at the arms base) is soldered to the which you're cutting.
58 comments
1-40 of 58next »
Jan 30, 2012. 8:47 AMdidgitalpunk says:
Why on earth would you EVER drill screws? just grab a star head screw driver (or whatever they're called) and unscrew those screws!
Jan 31, 2012. 1:56 PMdidgitalpunk says:
i don't see it -_- .
Sep 24, 2011. 10:24 PMfrostybob says:
Hey guys did as per instructable and nothing happens. Tried it on two HDD and still nothing on either. I didn't cut anything away cos i couldnt find my hacksaw. HELP???? and sorry.... It is possible I broke something because the reading things on the end looked pretty munted
Sep 24, 2011. 5:21 PMfrostybob says:
Horrible moment when your Torx set goes down to T-10...
Jun 25, 2011. 2:14 PMvader406 says:
Can you explain how hdds have speakers in them? o.o
Jul 27, 2011. 1:12 PMim3733 says:
They don't, the arm in the hard drive contains 2 main parts, the read/write heads, and the voice coil.
The voice coil operates in a reverse version of an electromagnetic generator, instead of the magnet passing through the coil, creating current, the coil is charged with current and moves through the magnetic field.
Applying a charge to the voice coil forces it to move to one side of the field, reversing the charge moves it to the other side. A soundwave, when convertd to an electrical signal, goes back and forth between a positive and negative charge very rapidly. When this signal is applied to the voice coil, it causes it to vibrate inside the magnetic field, acting in a similar manner to a speaker. These vibrations are understood by our brains as sound.
Jun 25, 2011. 5:59 AMrprough says:
The idea was cool enough but could have used more step by step photos. Only had a few photos. not much help.
Jun 25, 2011. 2:17 PMiminthebathroom says:
I agree, even if it is a little late to add pictures on the actual build, a couple close ups of how the wires feed in to it would greatly help. Grab a camera, snap a couple and add it to the all ready cool instructable! Hate to criticize an instructable, but this is meant as positive criticism. Many a time I have received comments like this and it only helped to make my instructables better. Thankyou very much for the cool post!!!
Jul 27, 2011. 1:02 PMim3733 says:
The connections you're looking for are the two that attach to its between the magnets.
Depending on your hard drive and the number of platters it has, your arm will have no less than 4 pins, 2 for the coil, and 1 for each side of each platter it writes on.
All you have to do is look at the pins on the arm, and follow the leads coming off of them to determine which is connected where. The rest is simple.
Dec 31, 2007. 4:11 AMunspecified says:
Is it really common in your area to own a drill press before torx screwdrivers?
Jul 5, 2011. 7:34 PMTOCO says:
That was in 2008. Now they are in everything. But I just take a dremel and cut a flat head across them.
Jun 29, 2011. 2:16 PMbtmarney says:
Torx on everywhere. If you take anything apart these days, you are going to find torx fasteners sooner than later. It's a must have set of tools.
Jan 5, 2010. 2:25 AMbeehard44 says:
if you own a bike, especially a mountain bike, you do eeda good set of torx screwdriver to adjust suspension, adjust basically everything......
And torx is used for the HDD.........
Jun 25, 2011. 2:13 PMiminthebathroom says:
neat idea, love the look! Perhaps everyone should think of this as a super cool mid to high tone speaker. Think I am going to have to try and make one of these, with the addition of some sort of sound box below it. Shouldn't be to hard to bolt one of these down. Perhaps before cutting the box apart clamp it down and drill bolt holes in the bottom. I'd say tap the holes but being aluminum after a while with those natural musical vibrations the threads would eventually break down.
Jul 7, 2008. 8:47 AMDerin says:
your gonna spend some time sawing,those HDD drives survive being dropped from five feet 10 times on a concrete floor(tested) while being opened up
and dont forget the "exposed to rain for a month in opened case"
Jun 25, 2011. 3:45 AMomnibot says:
Nope, it's all aluminium. A hacksaw cuts through it like a hot knife through margarine :)
Oct 10, 2010. 12:17 AMits2l8men says:
just use a grinder
Jun 25, 2011. 7:51 AMsnowluck2345 says:
or a bandsaw
Jun 29, 2011. 8:12 PMsockless says:
Just use a mill.
Jun 25, 2011. 2:50 AMscraptopower says:
This is so cool :) I HAVE to make it some time :D
Mar 14, 2011. 1:41 PMepalacios claussell says:
THIS is awsome im doing this thing for a project you did good i just finished in your last step its true that you should use a song with a lot of treble because if you had a song with a lot of bass you wouldn't be able to hear the song and couldn't really test it .......well good jb on this this is cool
Oct 31, 2010. 2:07 PMKiteman says:
Hey, I made one of these yesterday at the UK Instructables meet-up (other folk were making amplifiers, we had a pile of dead HDDs, the logic was inescapable...)
It works nicely, but volume was an issue (we couldn't screw the speaker down to the borrowed tables).
We found that light, rigid tubes (roll of paper, plastic cup etc) fixed to the arm gave significant improvements.
Thanks for the idea.
Feb 20, 2008. 10:25 AMKiteman says:
I guess I could fix one to my shed wall ...
Mar 26, 2009. 5:44 PMReCreate says:
Eh.. probably not if it is made out of wood it probably will stay very quiet
Mar 27, 2009. 4:55 AMKiteman says:
Wood is an extremely good resonator - that's how the vibration of string instruments' strings gets transformed into sound we can hear.
Sting vibrates bridge, bridge vibrates wood, vood vibrates air.
And paper covers rock.
Mar 27, 2009. 1:59 PMReCreate says:
Well if you do attach it to your wall you should attach it very tight so the sound passes through easily
and tornado sucks up paper
Jan 5, 2010. 2:22 AMbeehard44 says:
lol...
paper covers rock and tornado sucks up paper...
hehehe!
Nov 17, 2009. 12:39 PMstinger0410 says:
that is pretty cool and neat speaker you have there, good job:)
May 26, 2007. 9:00 AMAmadeos says:
well, is it crap or good, I wish to build one.
Mar 26, 2009. 2:22 PMJabariSmith says:
It's spelled "bass." Sorry, it was just bothering me.
May 26, 2007. 10:04 AMAmadeos says:
thanks
Oct 22, 2007. 1:36 PMShoeless Boy says:
Do you need the top magnet cause I have the same hard drive but I lost the top magnet?
Mar 24, 2009. 2:00 PMtbakhsh says:
no, actually most tutorials tell you to take it off.
Nov 16, 2008. 6:38 PMaman09 says:
So guys, I found a quick and easy way to improve the bass tones. Unfortuantely it makes the thing look super ugly. Regardless, the fix is to cut the top off a pop can and then tape it anywhere on the arm. If you don't mind it being ugly give this a try. It works.
1-40 of 58next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
81
Author:leevonk
www.leevonk.com
