More Durable Windsurfer Wi-Fi Extender
Introduction: More Durable Windsurfer Wi-Fi Extender
We all know about the Windsurfer Wi-Fi extender, but this is a more durable version of it.
Step 1: Materials Required
- Windsurfer Template ( Print above picture )
- Cookies or Candy tin
- Soft plastic ( i use a empty container of vinegar )
- Scissors
- Utility knife
- Glue gun
- Masking tape
- Lighter
- Sharpie pen
Step 2: Making the Reflector
Cut the reflector part of the Windsurfer from the tin.
Cut the slot in the reflector for the antenna mount.
Step 3: Making the Antenna Mount
Cut the antenna mount part of the Windsurfer from your soft plastic ( I use a empty container of vinegar ).
Cut slit in the plastic for the antenna.
Step 4: Assemble Your Windsurfer Antenna Extender
Insert the antenna mount tab into the slot of the reflector.
Use masking tape to help hold it together for now.
Melt and fold the tab using a lighter.
Add glue to old it all together with the glue gun.
Remove tape wen glue is cold.
Step 5: Install Windsurfer
Slide the Windsurfer on the antenna.
Now enjoy a more durable Windsurfer Wi-Fi extender.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    it does not say say in the instructions, but from the photos it appears the template should be enlarged.
    I don't think it will make any diference.
    Next time (or any time) you make a pattern for people to print and use, please place something on it which is a known size, and label the dimensions. My computer/printer likes to resize things to make them fit, so my print might be a bit larger or smaller than your original. Printing US letter on ISO A4 paper (and vis versa) also can cause the print to be re-scaled.
    I can measure something on my printout marked "this is 1 inch" and see if I need to have the pattern re-printed slightly larger or smaller to match yours.
    What did you use to cut the slots in the reflector?
    A dremel tool.
    How effective it is?
    I could not get wifi to work in my garage, now i get 2 out of 5 bar for signal.
    Not perfect but it work.
