More GPIO for ESP8266 - 01
Published
Introduction: More GPIO for ESP8266 - 01
About: Share - Learn - Makers. Projects, Articles, #automation, #PLC, #Arduino, #IoT and More PDAControl
The esp8266-01 module has a lot of applications programming either in company with arduino, or by programming only from the Arduino IDE interface.
This module is ideal for applications via wireless data transmission and the cost is the best unlike other costly inhalambricos modules. Since the ESP8266 - 01 only has 2 GPIO available,
I was forced to get another gpio, carefully perform welding on pin 14
More info:
Blog PDAControl English
Blog PDAControl Español
Step 1: Knowing Arduino IDE
Installation and configuration of Arduino IDE for programming ESP8266 Module - 01
Step 2: Components and Materials Required for Testing
1 Module ESP8266
1 Soldering iron with fine tip
1 wire thin copper
soldering tin
select pin 9 or GPIO 14
select GPIO pin 9 or 14 since it was the easiest position to be soldered copper wire.
Step 3: Testing...
classic blink test is performed and works very bn our new GPIO
If in the future there is a need soldare more pins ....
More Test....
Esp8266 blink test with new Arduino IDE 1.6.5 : PDA_Control
ESP8266 firmware update with Flasher ESP8266 : PDA_Control
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    3 Comments
    Excellent information. Thank you! Question: are the other pins in the ESP chip also accessible that way? Can we use all of them or is there a limitation?
    Hi, there is no limitation, it only requires a good welder and a lot of patience, look what a colleague did,
    https://twitter.com/absolutelyautom/status/718492213945245696
    Regards
