3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
40 More Handy Tricks
Step 19Inflate a Tubeless Tire That's off the Bead
Inflate a Tubeless Tire That\
There are several tricks going on here.
I've jacked up the vehicle so the tire can assume its normal shape.
I've wrapped a rope around the tread and tightened it by twisting a crowbar through it. That compresses the tread and forces the sides of the tire out, making it wide enough to engage with the rim.
A ratcheting tiedown strap is good for that also, but I didn't have one handy.
It would also be good to smear thick soap all over the bead and rim like they do at a tire shop.
I'm blowing air under the lip of the tire with an airgun. You can get a lot more air into the tire in a hurry that way to make it jump onto the rim.
2 comments
Apr 26, 2009. 2:20 PMThelonelysandwitch says:
Hey bud try this it is faster and more fun
May 29, 2008. 11:33 PMskunkbait says:
You can also do this by spraying a combustible aerosol into the tire and then throwing a match at it. The resulting explosion will (usually) inflate and seal the tire to the rim, also cutting off oxygen to the flame and extinguishing it. But be warned, have water handy to put out the fire in the event that it fails to seal!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1250
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
