3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
40 More Handy Tricks
Step 31Pressurize and Cap an Empty Soda Bottle
Empty soda bottles make good buoyancy chambers in a boat.
But when they cool off they contract and make crinkling sounds, besides losing volume.
Here's the gizmo I use to pressurize them while screwing the cap on. It's a chunk of bicycle innertube attached to a blowgun. The short part that goes over the bottleneck has an extra layer of innertube slid over it to handle the pressure. The long tail has three layers of innertube and is sealed with a knot at the end.
I loosen the bottlecap a turn or so.
Then I slide the short rubber tube over the neck of the bottle.
I grip the tube over the neck ridge and lean the airgun's lever against the table to pressurize the tube.
It puffs up from the pressure and the bottle gets hard.
Then I turn the bottle with my left hand while gripping the neck with my right, screwing the cap tight.
Another method is to put a small chip of dry ice in the bottle and then screw the cap on.
A reader suggests another method, which is put the bottle in the freezer for a while and then cap it when it's cold. When it warms up the air will expand and puff up the bottle.
4 comments
Jul 30, 2010. 11:26 AMsharlston says:
tim,i was wondering the innertube is it a normal mountain/bmx innetrube or a racing bike?
Oct 13, 2008. 5:10 PMegoncasteel says:
Another way to do this is to use canned air. The type you use to clean computer equipment. Just turn the can upside down and spray a little of the liquid in to the bottle, and put the cap on. Don't spray in to much or the bottle will explode loud as a gun shot a minute or 2 after you put the cap on. (unless you want to scare the crap out of every one in the office)
Mar 25, 2008. 7:44 PMdfairlie says:
Duh! I totally agree with chilip, I do that ALL THE TIME, its so much easier. In the winter I just leave them out ;)
Mar 22, 2008. 3:59 AMchilipähkinä says:
Easier way to make pressure in the bottle is to put them in the freezer cap open. Let em cool there for a while. Then screw the cap on while bottle is icecold and when air inside warms up bottle has some pressure inside.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1250
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
