3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
More Miles from Your Bicycle's Cassette
More Miles from Your Bicycle\
Nine speed cassettes (rear cog set) for your bicycle are not prohibitively expensive, but it would be nice to get a few hundred or more additional trouble free miles from them. A particular pattern of wear caused by the chain on the cog teeth creates problems that show themselves as chain skipping or hopping and poor shifting or hesitations in the movement of the chain from one cog to the next during shifting.
Pictured below is the profile of the gullet between two teeth on a typical cog.
Step 1The Hook
The Hook
Over time and use, a hook wears into the gullet profile as shown by the red color. This keeps the chain from sliding out of the gullet smoothly on every tooth during use. This hook does not need to be very pronounced for it to affect performance.
9 comments
Jan 27, 2011. 3:13 PMlarcrun says:
Heh Phil. I'm only familiar with one type of cassette, the shimano m760 9 speed and the rivet heads on outer side are flat with cog(so you would have to also grind cog face) and on the inner spoke side most heads are visible but indented into plastic spider so can't reach with grinder. Wondering what kind of cassette you have and/or how you do this rivet removal. Also, are you saying you only have to remove the small cog rivets? Not on mine.
Would sure like to try this and get more life out of cogs. Thanks for the excellent post.
Feb 9, 2011. 9:25 PMlarcrun says:
Yes, I have since learned that not all cassettes have the spider that blocks rivet head access that my XT unit has. Just saw a Sram PG970 9 speed that has a very small 1.5mm allen head screw on back that allows individual cog removal. I'm surprised you only got a couple hundred miles.
Oct 7, 2008. 5:51 PMiKill says:
if you take the hooks off wont it work even worse
Oct 7, 2008. 11:42 AMnagutron says:
If the cassette rings are symmetrical, you might be able to double their life simply by flipping them over. Can you think of problems with that?
Oct 7, 2008. 10:10 AMtoekneebullard says:
I look forward to the day I have to replace parts due to too much usage. Nice 'ible, thanks for the info!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
475
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
