3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
More mileage out of your Oral B Pulsar toothbrush
  • last photo ←
For around $5 you would think the battery in an Oral B Pulsar toothbrush would last a little longer. Here is how I overcame that problem.
Step 1The tools that I used
These are the tools I used. A pair each of vice grips, adjustable pliers, and small needle nose pliers (the smaller the better)
13 comments
Aug 15, 2009. 9:16 PMrhodesy01 says:
I have a much easier solution for the contact / switch problem. Just wedge a load of kitchen foil between the contact and the battery. That way when it is re-assembled theres a good connection and you can still use the normal switch to turn the toothbrush on and off. I use the same trick in my torch too because the batteries had a loose connection, it works really well !
Aug 2, 2009. 8:30 PMtehpirate says:
A toothbrush is supposed to be switched out every 2-3 months, which is about how long the battery in the one lasts.
Aug 5, 2009. 8:21 AMtehpirate says:
http://www.ada.org/prof/resources/positions/statements/toothbrush.asp
American dental association says 3-4 months, eh I was a month off but I'd rather not risk the chance of oral infections because of the bacteria a toothbrush harbors over time.
Aug 15, 2009. 7:52 PMPryer says:
id be sure to get the alcohol off tho. i once asked my dentist what would happen if i drank the rubbing stuff. he laughed and said "Youd die!" im not sure if thats true but now im afraid of that stuff.
Jul 17, 2009. 7:56 AMAndyGadget says:
What is the vibrating element like in those toothbrushes?
(And would it be suitable for making a Bristlebot?)
Jul 19, 2009. 11:23 PMAndyGadget says:
As you say - standard tiny pager motor. That's what I used for 'Blinky'. Anyone for a Bristlebot farm?
Jul 17, 2009. 2:25 PMcorksean14 says:
Its the standard tiny pager motor with off-kilter weight. perfect for bristlebots, I made my bristlebot out of one of these
Jul 17, 2009. 2:33 PMAndyGadget says:
Thanks - Sounds good to me. I'll have to look out for "2 for 1" offers.
Jul 18, 2009. 11:01 AMOryctolagus habilis says:
I think they're getting wise to this: mine was super-glued! It broke so that I could get it back together, but its impossible to make use of the threading, so I had to mess with it to make the switch useable.
Jul 17, 2009. 6:08 PMDa_Fudge says:
Nice 'Ible.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:nairda
