Mortises Made Easy
34,310
182
25
Published
Introduction: Mortises Made Easy
About: I enjoy the process. Who cares how long it takes?
A mortise-and-tenon joint is, as far as woodworking joints go, very strong and quite versatile. From stopped or through mortises to wedged or tusk tenons, you can have a lot of fun with these joints which can be as attractive as they are functional.
Some people use a dedicated tool (mortise chisel) in order to make their mortises, but this Instructable will show you how to make one using a few simple tools which you probably have around the house. I'll also give you a few options along the way, so you can see different ways to chop one.
After you're done here, consider this Instructable which gives you excellent tips on how to create the tenon that will fit into this mortise (and which also gives you some of the same advice contained here on the mortise).
Step 1: Layout
There are many factors that will determine the size of your tenon in relation to the board as a whole (in other words, whether you will have zero shoulders or four, or somewhere in between). So I'll leave that for another Instructable and simply say: Your mortise should be the same size as your tenon.
The only thing I'd add to that is that you'll have an easier time making your mortise if the mortise is the same width as your chisel, as you'll see in the next step.
Step 2: Chop Chop
Since the mortise here is 3/4" wide, I take my 3/4" chisel and start chopping away. In my very first chop (pic #1), notice the position of the chisel. The bevel is pointing towards the inside, and the blade is set in from the edge of the mortise. You can define the top and bottom of the mortise later.
Now that you've done that, move the chisel forward and give it a good strike with the mallet. Then pivot the chisel in the direction of the bevel; this will lever out the waste (pic #2). Continue to do this for the length of the mortise, keeping the bevel in the direction you are moving. See pic #3.
After you've done that, clean out the waste (pic #4). Depending on the hardness of the wood, you might be able to use your finger, or you may want to use your chisel or (in this case) a pocketknife. It doesn't have to look pretty - you're just clearing out the waste for a second pass. Pic #5 shows the status after the second pass. At this point, I take my chisel and pare the side walls of the mortise as well as better defining the top and bottom edges (pic #6).
A BRIEF ASIDE: Some tenons are intended to go all the way through the piece; they are called through tenons. If you were making a mortise for a through tenon, then at this point it would be a good idea to flip the board over and repeat these steps on the other side. Otherwise, you will eventually blow out through the other side of the board, causing tearout and other nasty things that will ruin the look of your piece. Make sure you are laying out your mortise precisely so the two sides meet in the middle!
This mortise is what is called a stopped (or stub) mortise, in that it does not go all the way through the board.
Step 3: Optional Drilling
Some people prefer to make their mortises by drilling first, and then removing the waste afterwards with a chisel. This definitely speeds up the process, but I would still advise doing the previous step of chisel work for two reasons. First, if your mortise will be visible in the finished product (like with a through mortise-and-tenon joint), then you'll want very nicely-defined edges, which is easier to do with a chisel. Secondly, having begun the mortise with the chisel, the drill bit now fits nicely and will not skitter across your workpiece.
In this case, I am making a stopped mortise, so I drop my drill bit in (pic #1) and have at it. I need to stop periodically to check the depth of my hole (pic #2) to make sure it's deep enough for the tenon. If possible, try to overlap your holes (pic #3), which will minimize your chisel work in the next step. If you have a drill press, then this is a very easy step, but if you are using a hand drill you will need to ensure you're not overlapping so much that the drill bit slips into a previous hole.
Once you're done drilling the holes (and if you didn't use a drill press), you might find it helpful to take the drill and go in at an angle to help ream out some of the waste (pic #4). Once you're done with that, you'll see something similar to pic #5. All the holes are at more or less the same depth. If you were making a through mortise, then hopefully the four walls will be mostly uniform the entire depth of the mortise.
Step 4: Final Cleanup
Now take your chisel and clean up the side walls, and also take care of that waste on the top and bottom. What you're left with is a mortise that, with a properly-fitted tenon, will be stronger than most of the other plans your lazy mind was devising to put those two pieces of wood together. Indeed, the exact same kinds of mortises I made during this Instructable were used on the 300lb workbench seen in the second pic. And I double dog dare you to try to break that thing apart.
Brackets? Screws? Pocket holes? Nails? Pshhhh. Who needs 'em when you have mortise and tenon joinery?
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    25 Comments
    Thank you. Your instructable made the work easy and such a nice finish!
    It's all about putting two pieces of wood together. :) Don't worry, if you work with wood, in time you'll understand it!
    Like so many other things, especially wood joinery, practice can make perfect. I haven't tackled mortise and tenon joinery jet, but intend to. I have, however, spent a lot of time perfecting box joints and each time it gets easier and fits better. Can't imagine that mortise and tenon joints are any different when it comes to perfecting your individual method. Great article!! Photos are spot on and the narrative is absolutely understandable.
    If you're starting out with this type of joint, you should lookup drawboring too; it can make even a sloppy and loose joint snug and clean.
    Right on the money! My workbench legs are drawbored together. A really quick search found at least 2 Instructables that show how to do it.
    If you were making a through mortice it would be faster to cut most of it out with a coping saw then clean up the sides with a wide chisel.
    It depends on the size of the mortise, but yes, that is a good way to start a through mortise! And then clean up the corners with a chisel.
    Actually it's best to use a chisel that is smaller than your mortise, so the edges of your chisel are not butting right up to the line on the sides. making the mortise slightly wider than you laid out.
    Well if you are chopping with a 3/4" chisel, you end up with a 3/4" mortise. My experience anyway.
    Yes, that's a forstner bit. It works better with my bit brace, since I don't own an electric drill. I borrowed one to ream out these mortises! :)
    You don't own an electric drill? They're cheap as they can get. You can get on for less than $20!
    I don't want one! :D
    Excellent... and a bench with a view
    "Pocket-holes?"
    You realise swear words aren't allowed here, right? ;)
    "Prison Pocket-holes" LOL
    Shhh... They're evil!
    Chop the mortise fist, cut the tenon to fit for a clean, tight joint. ☺
