3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mosquito Zapper
Mosquito Zapper
Modify a bug zapper to enable it to attract and kill mosquitos in huge numbers. Photo shows catch from one evening! Zappers usually are not effective against mosquitos, even when chemical lures are used along with them. The effective mosquito killers use propane and are large and expensive. CAUTIONS: This project requires disassembly and reassembly of an electronic device, and that should only be done by someone experienced in electrical matters and done with extreme caution. The finished project will also need to be used with extreme caution in order to safeguard people, pets and wildlife.
To see my related Instructables, including "Deer Fly Traps," click on "unclesam" just below the title above or in the INFO box to the right. On the new page that appears, repeatedly click "NEXT" to see all of them.
Unclesam
Step 1Disassemble zapper
Disassemble zapper
Any electronic bug zapper of any size will do. Zapper consists of two concentric cylinders made of coarse metal screen and fluroescent bulbs that attract some kinds of bugs. Mosquitos are attracted to warm-blooded mammals, however, and this project adds a sleeve of heavy black plastic to the outside of the inner zap screen. The bulbs heat the plastic sleeve, which attracts the mosquitos. Plastic sheet is an electrical insulator, but the machine will still zap with it in place.
Remove The protective plastic cage and remove the light bulbs. If these steps do not also remove the top electronic cover, leave it in place, no modifications to the electronics are necessary. Unsolder the wire that comes from out of the top of the unit and attaches to the top of the outer wire zap screen. Carefully remove the outer zap screen and any ceramic spacers. Cut heavy black plastic, such as 6 mil landscaping plastic, to a size and shape that will go around the inner zap screen once with a some overlap. Secure the plastic to the inner zap screen using an ordinary office stapler as far up as you can reach with it. If the top of the plastic needs securing, make a complete wrap of electrical tape around it, plus some overlap.
74 comments
1-40 of 74next »
May 28, 2012. 1:05 AMbigbadm says:
first of all, thanks for advice. ive opted for unrolling plastic within inner screen as i dont have a soldering iron.
also, i still managed to get a shock from screens after i had unplugged and removed bulb! also, are you sure there no fire hazard with plastic heating up?
thanks
May 28, 2012. 1:21 AMbigbadm says:
nb how important is it for the entire bulb to be covered, at the mo the very top and bottom of the bulb is still visible. will it still generate enough heat?
Mar 5, 2012. 12:59 AMJackRift says:
Mosquitos are attracted to the CO2 from your breath. Any time I need to clear an are I get some dry ice and set it at least 20 feet away in an open cooler. Maybe no snap and pop but very lethal especially if the cooler is highly contrasting with the environment
source: http://science.howstuffworks.com/environmental/life/zoology/insects-arachnids/mosquito.htm
Feb 12, 2012. 7:22 PMTakelababy says:
My so-called expensive mosquito trap that uses propane and lures is the only thing that makes my yard liveable in the summer. As the evenings get cooler the lure isn't necessary as the mosquitoes are drawn to the heat. The little basket is packed full of mosquitos every day for two months.
Jul 3, 2008. 4:13 PMPhilthy Phil says:
This unit (and one exactly like it) has NOT WORKED at all. There are bugs all over the place here, and I have done the "mod", and the zap test results in NO ZAP at all. Obviously there are no dead bugs either. This is a ripoff.
Jun 8, 2011. 8:52 AMjbodden1 says:
I have my questions about insulating any part of the zapper coil/lattice too - again I will say that if one only wants heat to draw the bugs you can replace (or add to) the light with ceramic insulated resistors - and the heat can be controlled, as it is not with a light bulb.
High voltage is not fond of trying to get through an insulator.
Jul 7, 2008. 10:09 AMPhilthy Phil says:
Still does NOT work. Cannot remove the top to expose wiring and transformer unless I take a hacksaw to it. How many volts does the transformer put out? If I know this, I will compare it with a volt ohmeter. I suspect low voltage or no voltage at all.
Jul 8, 2008. 7:28 AMPhilthy Phil says:
My model IS a Stinger. I thought my older Stinger model was defective, so I purchased a new one...SAME RESULT. These Stinger bug zappers are WORTHLESS. The only way I can remove the top is either with a slotted screwdriver and prying it off (high risk of fracturing plastic top) or using a hacksaw. The bug zapper my father had was obviously NOT a Stinger...and it worked flawlessly. This is a total waste of money.
Jul 9, 2008. 8:53 PMPhilthy Phil says:
I hope you're right, because I ordered one of those UV801's today. Incidentally, the current bug zapper (40 watt) does not kill bugs...even with the mosquito attractant. Look at it this way...the more bugs you can kill, the more birds you'll be feeding. Hopefully this will prolong man's existence on this planet, because it ain't gonna be human beings who take over...it'll be bugs (insects) and weeds (plants).
Jun 8, 2011. 8:59 AMjbodden1 says:
INTERGALACTIC crime fighter? There weren't enough politicians and lawyers HERE to keep you busy?
Jul 10, 2008. 10:56 AMPhilthy Phil says:
Well, I hope my "uv801's senses" are able to detect these little vermin that make it impossible to mow a lawn or trim roses or have a backyard barbeque, and make bird food out of them. I can't wait to plug it in...and HOPEFULLY listen to the snap, crackle and sizzle...and hope it wakes up the whole neighborhood!
Aug 14, 2008. 9:28 PMPhilthy Phil says:
I finally received my UV801...albeit 3 weeks late! Certainly works much better than the lower-priced models! I tried your "trick" assembly with the black plastic and discovered it did NOT WORK at all (NO ZAPS with the wet paper). In the process of removing the plastic and reassembling the unit, both tubes fell to the floor and were destroyed. Now I have to order a new set at a cost of over $30...and wait for them to arrive before witnessing more snap, crackle and pop.
Mar 21, 2009. 11:45 PMsolarmatrix says:
see comment to philthy phil
Aug 18, 2008. 12:19 PMPhilthy Phil says:
Yes, as soon as I reassembled the unit, the zap test was normal. I am NOT going to fool with it anymore...just leave as is and hope my replacement bulbs will arrive before the "bug season" has past. I have no idea how you can place plastic INSIDE the inside screen without touching the bulbs. I detect a bit of facetiousness on your part regarding "exploring instead the other categories of instructables, such as knitting or flower arranging". Perhaps you might want to explore these yourself.
Mar 21, 2009. 11:44 PMsolarmatrix says:
amidst the trail of dangerous and broken zappers I couldn't agree more about exploring other categories. those with electronics knowledge should try the "supercharged lemon" Instructable. it works well, is safe, and can be scaled up to do more work. This is an example among a thousand that are more interesting than watching bugs fry fellas. thats you too uncle sam.
Jun 8, 2011. 9:03 AMjbodden1 says:
Ah, but the emotional satisfaction of watching those bloodsuckers go POP!
Ditto for lying politicians and crooked lawyers... maybe if I put money inside the bait tray...
Feb 12, 2010. 7:01 PMbrunfelsia says:
Is there a simple way to permanently disable the electric zapper grid while preserving the UV light in the typical bug zapper? Anything to be careful about? A very small few of us actually would like to use some of these relatively inexpensive portable zappers as attractants / collectors to collect insects for study at different sites, but obviously the electric discharge through the insect body renders it essentially useless as a specimen for study. If it is easy to disable the shock grid, then the unit could be modified over an alcohol (or antifreeze) or other collecting bucket to catch and collect insects that simply fall in after being attracted to the light.
Jun 8, 2011. 8:38 AMjbodden1 says:
Just a suggestion - but to keep the light drunk bugs from flying away after they recover why not make a framework (plastic 5 gal bucket with cutouts leaving framework), stretch cheesecloth over it, leave a few holes for the bugs to find their way in and some kind of drawstring arrangement to close it up (triggered by light at dawn?).
As it uses no poisons or zapping, your specimens should be virgo intacto with the exceptions of those that eat the others...
Feb 13, 2010. 1:07 PMbrunfelsia says:
Thanks so much - I will try this approach and see if I can make a couple of collector conversions!
May 28, 2009. 8:56 AMneofling says:
has anyone tried painting the bulbs with black paint rather than using the plastic? is there anreason i couldn't just tape black plastic sheeting directly to the bulbs?
Jun 8, 2011. 8:27 AMjbodden1 says:
Depends on the bulb- you might just burn paint and put the bugs off - if all you want is heat try some ceramic resistors - you can even dial them in to 'body temperature' if you want. Producing just the amount of heat you want, without producing light is likely to be more energy efficient.
Jul 3, 2009. 10:26 PMdevin8 says:
Hello Sam. I want to build a bug zapper that will kill yellow jackets. We have scads of them in hills of Bay Area, and they chase us inside in August/Sept, when eating outside in warm evenings would be delightful. Scent based traps are not effective enough. They kill some, but I think the wasps are getting more selective against that bait type.
I'm thinking high voltage DC power supply (~4kV), and perhaps 1-2mA with a ~10mm gap between screens. Yellow jacket lands, crawls across, and whap! Any suggestions on target voltage/amperage? Would you do this with a high voltage power supply, or with cap discharge? Check out the following mfg for the power supply. http://ultravolt.com. Looks reasonably cheap to me. I've heard from friends that the high voltage cap discharge "tennis rackets" don't have enough punch to kill a yellow jacket.
Jun 8, 2011. 8:42 AMjbodden1 says:
Seems to me that if you want to bait yellowjackets, try hamburger - those suckers just love raw meat! And watermelon juice...
How about a trap that just stuns them and they fall into water? Bugs can't swim - water beetles and such excepted I guess.
I do know that I have to make special watering dishes for the honeybees or they fall into the dog bowls and drown just trying to get a sip.
I wanted to figure out a way to coax yellowjackets into a blender but that is still a work in progress... and best way to kill yellowjackets in house or attic is with steam cleaner. Wait until nightfall, they all return to nest - steam will cook them even in flight and kill all eggs.
Jun 18, 2011. 8:22 PMCAbeachguy says:
The reason I'm looking at this instructable thread is because I wanted to build one to deal with carpenter bees. I have a log house and they are eating it up. I'd love to know of the "other kinds of efficient measures against them you have come up with. And...I'm desperate at this point.
Thankx
Jul 13, 2009. 8:18 PMdevin8 says:
Thanks Sam. I'm back from vacation. I appreciate your response. I have made similar traps using empty milk jugs. They catch a few. I find that the wasps tend to often find their way out, or can't find their way in. As such, I'd still appreciate some feedback on the zapper idea. Curious why your power supplies burned out. I was thinking about just buying the DC high voltage power supply from the link (or building one from a circuit diagram in "Art of Electronics"), feeding it w/ ~12V DC from a laptop brick, having it put out ~2000V to the load. I'm thinking the load would just consist of resistance in series to prevent an overcurrent condition, and capacitance across output to build up the charge. The output is parallel screens. I talked to a friend that configures laser power supplies, and he suggested about 1uF as adequate capacitance. I figure I'd try enough resistance to generate a 5-10sec recharge time for the cap. The tennis racket style bug zappers use DC voltage to charge a cap. They run at about 500V. The bug shorts the cap. I think the idea should work. AC probably works better, and is a cheaper circuit, but I think they'd be more dangerous. Did I mention that I stepped in yellow jacket nest just before posting this inquiry? Got stung about a dozen times. This is about payback!!!!
Nov 13, 2010. 4:18 AMmarkee2 says:
the illustration of how to disassemble the zapper is good. if
you are planning  to build  a simple mosquito zapper circuit
maybe you can follow or copy this diagram. it might help you.
copied from
 http://www.simple-electronics.com/2010/01/bug-zapper-circuit.html
Mar 13, 2009. 2:03 PMsolarmatrix says:
The most effective mossie traps produce carbon dioxide by using UV light radiated across a titanium dioxide coating located inside the trap. A fan sucks the unsuspecting mossies into the trap and also this creates a breeze associated with moving breathing mammals along with the warmth of a bulb ballast. this is the best combination off all. I have done hours of research into this subject and performed my own experiments. the vertical killing grids found in the BEST zapping killers are in the the FLOWTRON range of killers these require NO cleaning as ALL the insects fall as they get zapped (think jacobs ladder in reverse!) and are more effective against mossies because the spacing of the grids can be less for the same voltage before flashover/short. I was going to make a vertical grid (each bar opposite polarity) for my zapper after I had seen these perform. this with the titanium dioxide paint on the inside would be the killer combo a plain painted bulb sounds safer if high temp paint used. best of luck. but threre is more to life for me these days, being mossie/bug free these days. got em all!
Mar 21, 2009. 10:28 PMsolarmatrix says:
The air around us is a mixture of gases, mainly nitrogen and oxygen, but containing much smaller amounts of water vapor, argon, and carbon dioxide, and very small amounts of other gases. Air also contains suspended dust, spores, and bacteria. Photocatalysis is a catalytic reaction formed when TiO2 is irradiated by near ultraviolet rays from the sun or a light source. In the presence of near ultraviolet light, Titanium Dioxide (TiO2) breaks down organic matter in the form of airborne microorganisms (such as airborne bacteria, mold, viruses, fungi, smoke and household odors) into carbon dioxide (CO2) and water (H2O). the amounts produced are small as are the requirements. the propane units usually work by burning the gas to make heat and co2. I'm aware the dangers of fire relating to globes and the type i use are fluorescent which radiate little heat even at the end/s. I cannot stress enough the dangers associated with modifying such mains devices that produces even higher voltages/danger I can tell from your comments posted on the diagonsis of why other readers units failed to "work" with your modifications that you dont quite hold all the cards in this deadly game. there are a huge varietly of zappers on the market with all different circuits and or transformer specs producing ac or dc voltages between 1000-6000 volts at a variety of currents. I have worked on many. To suggest that this dangerous mod is suitable for any zapper is not wise at all. I suggest you do some further research into electrical safety. Dont rely on experiments of your own and other readers with this matter. good luck anyway! MaTrIX
1-40 of 74next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:unclesam
