Most Basic Form of Hydroponics by AgentWolf
This hydroponics set up can be easily made using household items.Only thing you will have to buy is the nutrient solution.
By reusing household items you are reducing waste. Because this setup is outside you are using sunlight and no artificial light is required.The water and nutrient solution mix can be reused.
A reservoir consisting of a bucket with Spigot (Tap Valve) attached at the base contains the nutrient solution and is placed above a tray filled with the hydroponic medium which in this cases happens to be small pebbles. The nutrient mix is allowed to drip at a low rate providing a constant supply of the solution to the roots. The solution after having gone through the container housing the hydroponic medium and plants is then drained and collected in another bucket. Once the drainage (collector) bucket is filled, one must recirculation the water back into the first reservoir manually. This method keeps the medium regularly flushed with nutrients and the solution mix can be reused.
Step 1: Parts
One of : Bucket with tap
One of : Plastic Planter
One of : Normal Bucket
Solution Mix :
Dutch Nutrient Formula Gro A  and Dutch Nutrient Formula Gro B
http://www.dutchnutrientformula.com/gro_bloom/gro_bloom.html
Browncoat says: Jul 20, 2012. 8:56 PM
You might be able to enter this in the Water Challenge.
http://www.instructables.com/id/Summer-Water-Challenge/
AgentWolf (author) says: Jul 21, 2012. 5:03 AM
Thanks for letting me know.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
