Most Compact Low Voltage 10hour Timer
607
5
Posted in TechnologyElectronics
Introduction: Most Compact Low Voltage 10hour Timer
Many timers are there
simple with basic parts no IC =not there
The timer at low voltage =not there
Unless you get low voltage 555 you cant make .
Many parts of the world the special chips need 30days to reach .
So i tested the timer with FET and BJT pair.
Step 1: The Devices
The devices tested were TO92 packages , can be done point to point solder .
slight changes can allow relay trigger too .
Step 2: The Circuit Is ...
The FET is like a switch with gate getting a +ve , the lower 1m is to cancel internal capacitance effect.
The BJT is a very low voltage switch as the neno amps of charging for the cap makes it on. without the BJT part the FET is wired in ON mode and as BJT "eats " the GATE voltage as long as the capacitor charging. The cap can go 1000uf making 10hour or more time possible .!!!
Step 3: Build Proto ,conclusion
well the proto was a point to point test jig ..will post a superglued build
soon..
Bye
Step 4:
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
