Step 6Soak off the paper
iImage Information
Drop the hot board immediately into a pan of hot water, along with any of the paper towel that might be attached. Some of the paper will start to come off right away. Help it along! After a few minutes, more paper can be pulled off. Also peel off any scotch tape you used to hold the mask to the board. After 10-20 minutes, you'll be down to the last layer, which is more like plastic than paper. The traces will be clearly visible though it. Get a corner started, and the plastic should peel off easily, leaving you with a nicely masked board. If you've ironed well enough, the toner will be fused to the board solidly; it can't be scraped off with a fingernail.
If the traces are messed up in any way -- for example, if the iron slipped -- you can clean off the fused toner with acetone and start over with a fresh mask.
I have also heard that paper with "high clay content" is what you want to use. Also, that glossy magazine paper, light, with as little printing as possible on it works. I haven't tried either but have heard they work. Like I said earlier this step is such a pain I just don't like to mess around with it.
Here is a link to the real thing:
http://www.techniks.com/information.htm
