3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
(Mostly) easy PCB manufacture
Step 9Apply the silkscreen layer
Now it's time to add the "silkscreen" to the other side of the board. It's not really a silkscreen; it's actually the same process as described above, except that you leave the fused toner on the board and don't do the etch and cleanoff.
To align the "silk", I drill a hole in the four cornermost pads. After cutting out the silk mask, I place it toner-side-down against the side of the board opposite the traces. Holding it up to the light, you should be able to see the four corner holes through the mask. Use these to line up the silk mask properly, then tape it to the board with scotch tape. Next, iron the board the same way you did the copper side, and finally soak off the paper as in step 6.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:guerroloco
