3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Motherboard PCB Bracelet
Step 5String Them Up
String Them Up
Now after the holes have been drilled I recommend you wash the pieces again to remove any dust substance.
I was thinking of using elastic to hold the bracelet together but there wasn't any available so I used some telephone wire (a single strand) which nicely comes in a variety of different colours!
If you are using elastic you don't need to follow the next step, just tie the elastic so there are no ends.
2 comments
Jul 20, 2011. 6:18 AMitobor2525 says:
This should allay your Pb poisioning fears: I made a bracelet like this; I sprayed the underside of the segments w/clear varnish/lacquer (buy a can at the local hdwe store or Lowe's). Afterwards I attacged a thin layer of white felt (it came pre-glued but) I added a few drops of stupor glue to the pieces. I think I'll spray the top sides as well when I make another. I do like the molex power cord concept; although I might alternate the wires for a different effect.
Great idea for repurposing; kudos.
Sep 28, 2009. 9:44 AMDysphoria says:
Why not solder the underside? If you solder correctly, it wouldn't feel uncomfortable. :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:ll.13
