3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Motion Detector Cat Fountain
Our cat, Murray, had gotten into the habit of preferring to drink from a slow trickle in the bathroom sink.  This wasn't always convenient for us, so I decided to modify a pet fountain.  After checking out several of them, I went with the Drinkwell Platinum.  It has a carbon filter, adjustable stream, large reservoir, and is pretty quiet.  I didn't see the need to have it run constantly, so I wanted to put a motion detector on it to run only when he came near.
This ws a pretty straight forward project and turned out really well.  Murray loves it.
Step 1Motion Detector
Motion Detector
If the fountain is the body of this project, the passive infared motion detector (PIR) is the brain.  I didn't have to search very long to find the perfect detector.  It was very small and simple to wire into a control board.  I found it at http://www.glolab.com .  The detector itself fit perfectly into a 3/8 inch hole I drilled in the front of the fountain frame.  It took me a little time to figure out the best way to hook it up since it has a dedicated relay out.  It turned out that since I was using a solid state relay to activate the pump, the standard out worked best.
The additional items necessary for this project are a small perfboard, 180 ohm resistor, 7805 voltage regulator, AQH2213 solid state relay, 0.1uF capacitor, 10uF 50V capacitor, 1000uF 25V capacitor, a bridge rectifier, 2 Molex KK connectors (male and female for each), and a 3 pin header.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:bkr1969
