3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Motion Sensor Cat Toy (endless fun... literally)
Step 2What each part does
What each part does
" Motion sensor: Detects motion from 20 feet away. When motion is sensed, a single bit output (electrical current) is created. This goes to the microcontroller chip.
" Microcontroller chip: When 5 volt message comes from the motion sensor, the microcontroller says turn on the motor for 5 seconds. My brother helped me with the code and we used his board to put the code on the microcontroller chip.
" Capacitor: This is between power and ground to smooth power to the microcontroller. The capacitor should be as close to the chip as possible.
" ET Tiny 25 chip: The chip holds the code. The code is the brains operating the motion sensor and motor based on electrical impulse.
" Voltage meter: The meter is used to measure how much DC voltage all the parts (motion sensor, motor, and resistor) take. If the voltage isn't correct, things burn up.
" Power brick: The power brick plugs into the wall and sends electricity to the unit (+ and  charge).
" Solder: The solder is fusible metal which connects wires and keeps the current flowing. I used a soldering iron to melt the solder on the VHS board to remove the capacitor. I used solder to attach the wire needed to make the circuit. Always us goggles.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:Kateham
