Aside from using it in a POV device, you can also use it as a general purpose tilt sensor. The sensor is equivalent to two SPST (single-pole, single-throw) switch or a DPST (double-pole, single-throw) switch where only one pair of contacts is closed at any one time.
A metal ball bearing completes the electrical path between a pair of pins on either end of the tube. That's as simple as it gets.
Remove these ads by
Signing UpStep 1Tools & materials
- Long nose plier
- Wire cutter
- Utility knife
- File
- Rotary tool with grinding bits
Materials
- Super glue
- Double-row, right-angled PCB header
- Metal ball bearing (must be large enough so that it won't slip between the PCB headers)
- Ink tube from a pen (must be large enough so that the ball bearing can freely slide inside it)
I need a very simple and very small tilt sensor for an upcoming project, so thank you so much again.
Is your dad Macgyver?
Simply Brilliant
