Introduction: Motion Sensor
School project. Feel free to use it for your school project.
Aurdino UNO
LED
PIR motion sensor
jumper wires
Step 1: Add the Wires to the Sensor
Take the jumper wires and connect male to female from the motion sensors CVV to 5V, then do GND to GND, and finally OUT to Digital pin 2. This will sen our code to the aurdino and send if motion is detected.
Step 2: Code
write this code for it
// Constants
const int pirSensorPin = 2; // Pin connected to PIR sensor
const int ledPin = 13; // Pin connected to LED
void setup() {
pinMode(ledPin, OUTPUT); // LED pin as output
pinMode(pirSensorPin, INPUT); // PIR sensor pin as input
Serial.begin(9600); // Initialize serial communication for debugging
void loop() {
int pirState = digitalRead(pirSensorPin); // Read the PIR sensor state
Serial.println(pirState); // Print the PIR sensor state for debugging
if (pirState == HIGH) { // If motion is detected (PIR sensor outputs 1)
digitalWrite(ledPin, HIGH); // Turn on the LED
} else { // If no motion is detected (PIR sensor outputs 0)
digitalWrite(ledPin, LOW); // Turn off the LED
Step 3: Connect Led
Connect the led to the Digital pin 13 and the GND pin. The longer one to 13 and shorter on to gnd. You finished your project!
