Motion Sensored Security System
10,244
282
8
Posted
Introduction: Motion Sensored Security System
This is a security system using an Arduino uno and a PIR motion sensor which triggers an alarm when motion is sensed and is best in securing you house from burglars.This project is useful as, when burglars hear the alarm ring loudly they often run off!
In my project i have used a relay circuit configured to the Arduino so that 12v could be given to the buzzer for a loud buzz!!!
Step 1: The Parts You Will Need
Parts List
  1. An Arduino UNO
  2. A PIR motion Sensor
  3. Jumper pins (male to male and Male to female)
  4. A 3-242V loud buzzer (HYT-3015B)
  5. An Arduino Relay Shield or my Relay Circuit
  6. A 12v battery or Power supply
  7. Some alligator wires (if you prefer not to solder)
Step 2: Making the Relay Cicuit
Parts you will need
  • A relay (SRD-12VDC-SL-C)
  • 10K Resistor
  • IN4007 Rectifier Diode
  • BC548 Transistor
Circuit
I have given the schematic below for the Relay to work with the Arduino in the word document below and after the circuit is complete you can test it using the Relay test code I made and it is too provided below.
Step 3: Connecting the PIR Motion Sensor to Arduino
Grab some jumper wires and connect the female side to the PIR motion sensor’s VCC, OUT and GND pins. Then connect the male side of VCC to 5v in Arduino, OUT to Digital pin 2 and GND to any GND pin in Arduino.
Step 4: Connecting the Relay Circuit to the Arduino
Connect the wires from the Relay circuit to the Arduino as shown in the picture leaving the Buzzer’s wires only. After that it should be something like this.In my case the buzzer's wires are the green and brown one.
Step 5: Connecting the Buzzer and Powering Up the Project
Connect any one buzzer wires from the Relay circuit to the buzzer's positive wire and the other remaining wire to a 12v positive power source.Then you connect the buzzer's negative wire to the 12v power source's negative wire.
Step 6: Finalizing the Project
After all connections are complete upload the code i have given below to the Arduino and power up the Arduino using a 9v or 12v power supply.
Further improvements
There are many improvements for this project such as adding a 12v LED to the relay while the buzzer is connected and also adding a camera would mean that the Arduino could capture images in light of the burglar or by using a Arduino GSM shield the Arduino Could send the pictures immediately to the house owner.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
8 Comments
Hey do u think I can hook one of the 12v flashing warning lights to this system as well? In conjunction w the buzzer. Like the spinning yellow warning lights on emergency vehicles? If so how would I do it?
yes by hooking it up to the same relay or adding another relay mdule!
How would I connect a IR sensor to control this project.
This might scare anyone out of coming into my room at my mom's place
Great idea! Thanks for sharing!
Your most Welcome sorry for the late reply!!
I can't Download the Relay Schematic
is there any way to download relay schematic
