If you like this instructable, please vote in Hack it contest and DIY audio contest.
Basic idea:
The block diagram is shown below (block diagram). The motor is rotating in constant speed. There are dark (non transparent) and transparent portions on the CD. When the dark portion of the CD is between the IR emitter/detector, the resistance of the detector will be high, and the voltage across the speaker will be low. When the transparent portion of the CD is between the IR emitter/detector, the detector receives the signal from emitter, and its resistance will be low, so the voltage across the speaker will be high. The voltage signal across the speaker is a square wave. By varying the speed of the motor and dark/transparent portions on CD, the frequency of square waves signal changes. You can hear the changes from the speaker.
Remove these ads by
Signing UpStep 1: BOM
BOM:
Two 1.5V AA battery and battery holder (Radioshack Model: 270-398)
One 3V DC motor and CD holder (Search “Spindle Motor for DVD CD Player” in Amazon)
A pair of Infrared LED Emitter and Detector (Radioshack Model: 276-142)
Two 1N4001 diodes (Radioshack Model: 1N4001) (optional)
One 22ohm and one 68ohm resistor (Radioshack Model: 271-312)
One 12-Position European-Style Mini Terminal Strip (Radioshack Model: 274-680)
Hookup wires (Radioshack)
Small speaker (Radioshack)
M3 screws, M3 nuts, ¾ inch thick plastic block, 1/16 inch thick X ¾ inch aluminum angle, ½ inch X ½ inch square plastic block, three 8mm M3 screw spacer, double-sided tapes (McMaster)
Visit Our Store »
Go Pro Today »
One could totally encode things on the disk, like morse code or songs.
Good suff!
