Motor Gear
1,610
34
Posted in TechnologyElectronics
Introduction: Motor Gear
A clothing or gear is a rotating machine part with cut teeth, or cogs, which mesh with another toothed part to transmit torque, in most cases with human teeth in a form identical clothing, and often with that form in other clothing. Two or more gears working in a sequence (train) are called a gear train or, in many cases, a transmission; Such agreements can produce garments mechanical advantage through a gear ratio and can thus be regarded as a simple machine. Customized equipment can change the speed, torque, and running a power source. The most common situation is for a gear to mesh with another gear; however, a dress may not mesh with a rotating toothed part, called a rack, producing translation in rotation spot.
Gears in a transmission are analogous to the wheels in a belt pulley system passed. One advantage of gears is a gear teeth to prevent slippage.
We have several types of gear that only some gear I have used Parent Forum has strengthened a lot but also engine has slowed
Step 1:
That in this schematic of some types of jagged and I have adapted here as I've noticed a change because the speed has been reduced and the power is increased, this is a special phenomenon that this also you can show.
You can also visit my facebook while here you do like to see my project with this link : https://www.facebook.com/pages/Electronic-induction/794306237284409?ref=bookmarks
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    2 Comments
    hey u can use blank circuit board instead of plane wood for the base , it would b less mess...
    Power transmission using gears is fun, I like to play with them too, and your breadboard testing method is very clever for finding the centers.
