3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Motorcycle Accessory Wiring
So you want to run some accessories off of your motorcycle's power, but your bike doesn't have an accessory circuit or anywhere to plug things in? Here are some quick tips on how to do it.
Step 1Identify a circuit to use
Presumably your motorcycle doesn't have a dedicated accessory circuit, or you'd just be using that. So get a copy of your bike's wiring diagram and find a nice non-critical circuit (just in case we screw things up, we don't want to mess with something that'll stop the bike from running or that'll kill important safety equipment, like brake lights).
Make sure the circuit is suited to your power needs. The wattage that your accessories draw should be well below the power limit of the circuit. For example, if the circuit has a 5A fuse on it, make sure you are using considerably less than 12V * 5A = 60W. Keep in mind that you have to add up all of the draws (including the ones that were on the circuit before you start adding accessories). Don't cut it close. Don't replace the fuse to allow more current.
My bike has a circuit for a light that serves only to illuminate my license plate. Perfect!
After reading the wiring diagram, follow the colored wires to find the appropriate pair. Test to be sure it's the right circuit by unplugging it and seeing what turns off.
11 comments
Dec 11, 2010. 3:48 AMDynoJunky says:
you shouldnt connect any electrical equipment to your bike like this. check the amps. use a 12volt relay. - adding a pair of fog lamps 110 watt- on a circuit used to power a 5 watt peanut bulb with a 5A fuse - recipe for disaster.
Dec 13, 2010. 1:46 AMDynoJunky says:
yes, a blown fuse every time you want to use them, leading you to put a larger fuse on the circuit. cable that cant cope with the amps that you are forcing down it will melt and or catch light. but then i guess the problem will be solved no more bike = no more electrical disaster.
Oct 29, 2009. 5:36 AMAsmodeo says:
Hi, Aneel! Nice instructable!
I've a 1980 CB750-F Super Sport Honda, and I added some "fog lamps" the same way You did here.......and realized that It had an"accessory connector" hidden into It's guts (obviously, I found It when my job was done...)
Also, I noticed a little error in your first photo:
RED cable is for the positive , aka "power", or "+"
BLACK cable is for the negative, aka "ground" or "-"
Anyway, the instructable is clear enough to save our beloved electronics from death!
Oct 30, 2009. 5:53 AMAsmodeo says:
Aneel, no puning intended....It was always clear for me (electronic engineer)...It was just "for the kids"  =O)
Thanks a lot for the info, red rider!
Jun 15, 2009. 12:31 PMlemonie says:
What bike have you got? I'd be nice to add a picture L
Jun 15, 2009. 11:27 PMlemonie says:
Ah great GPS, thanks. L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:aneel
