I've been thinking about these for a few years and just didn't get around to making them.
Lowers are deflectors that mount to the forks and deflect the wind away from your legs and keep it from kicking up under the windshield and into your face.
The solution I came up with is fairly simple; easily acquired materials and hand tools will get the job done.
Before you start, read all of the directions and look at your bike to determine what adjustments in materials you may need for the size and mounting conditions you need to work with.
If you plan ahead and purchase all the materials you need, you can complete these in about an hour.
Lastly, there will always be those that think these are not finished enough to put on their bike. So don't.
My bike is strictly for commuting and running errands. It is a workhorse and not a show piece (although it still looks pretty good.
I commute down to about 18 degrees F, so I'm more interested in utilitarian concerns during the winter than looks.
That being said, these things are a nice compliment to the windshield and homemade hand deflectors (see other Instructable).
Remove these ads by
Signing UpStep 1Materials and Tools
- Lexan polycarbonate sheet: I needed (2)pieces about 17" x 5". I purchased a .093" thick 12" x 24" sheet for around $13 from Home Depot..
- Aluminum angle: I needed (2) pieces about 17" long. I purchased a 3/4" x 3/4" x 1/16" x 36" piece of aluminum angle for around $7 from Ace.
- Adjustable straps: I needed (4) straps for approx. 3" diameter application. I purchased (4) stainless steel adjustable straps for about $2.40 each from Ace.
- Machines screws, washers and lock nuts: I purchased #10-24 x 1/2" stainless steel machine screws, washers and lock nuts from Home Depot.
- Cardboard for making a template
- Old bicycle inner tube
- Some kind of tape - Optional
- Piece of rubber bungee cord (to act as spacer) - Optional
- Jigsaw for cutting Lexan
- Hacksaw for cutting aluminum angle
- Drill (I used a drill press) for drilling aluminum angle and Lexan
- Sheet metal shears for cutting adjustable straps
- Files for smoothing cut edges of Lexan, smoothing cut ends of aluminum angle, elongating the drilled holes in angle to make slots, smoothing cut edges of straps
- Dremel tool for elongating the drilled holes in angle to make slots
- Screwdriver for adjusting straps
- Writing implement (I used a Sharpie)
May I suggest that if You want it almost airtight against the fork, You may mount the Lexan on the outer side of the aluminium angle, with a full lenght metal strip between screw-head and Lexan to ease the mounting pressure?
The inner side of the deflectors can be cut to fit around clamps and lower fork quite tight.
I did something like it on an old Suzuki 750 "Water Buffalo".
I mounted some house siding on the crashbars and then made a collector from the radiator to (2) 3" hose run up into the Faring to bring heat up to my hands
Made for much nicer winter riding.
Really man, how?
Full face helmet (I usually ride with the shield open because I wear eyeglasses and they tend to fog up with the shield closed, even though I use anti-fogging coatings)
Motorcycle jacket (Joe Rocket Alter Ego - best) over top of polar fleece and dress shirt (layers)
Overpants (First Gear) over dress pants (layers)
Over-the-ankle boots
Wool socks with dress pants tucked into them (keep the wind from blowing up your pant legs)
I have heated Gerbing gloves. All other gloves I have tried (a lot) didn't do it for me below like 28 degrees for my commute. They were either too bulky to use controls or didn't provide the warmth I needed. My commute is 40 minutes of stop and go, so lots of time on the brakes and clutch, hence, cold fingertips. Therefore,heated grips wouldn't work for me.
Toes and finger tips are the extremities that are hardest to keep warm.
How I went the last time in 2011 (too cold for me later) :
2 bandanas, large one over the bottom of the face and neck, smaller one on the neck
a vest, a shirt, a sweatshirt or something similar ( regular clothing ) and a normal motorcycle jacket ( double layer )
thermo pants ( not very thermo, only thin ones, so I do not cook myself during the day )
jeans, skiing pants
regular socks, skiing thermo socks, regular trainers.
I am not an old motorcycler or something, I just started -
I got my license in the summer and my Suzuki 125 Marauder in September/October maybe, done 2000km since.
So your advice is appreciated, thanks.
And, not to be so off-topic: You wrote, that someone may find these not finished enough - well, I think they are perfectly OK. From the picture I would guess those are original, straight from the factory. So good work.
23 degrees here in Phila.
The tires don't seem to be an issue, although I've often wondered about that myself.
I have a 2003 Victory, and you betcha this is on the winter project list. Right now, without lowers, I get so much air coming up from underneath the windshield, at highway speeds, I can rest my arm on the air like it's sitting on the edge of a table.
Let me know how your deflectors work out.
The lower leg of the fork moves up and down into the section I mounted these to.
The metal angle allows the lower portion of the deflectors to "cantilever" past the bottom edge of the fixed fork section and "float" past the moving fork section.
It would be quite easy to bend the plexiglass if you had a wooden mould around 4" diameter cut in half, a heat gun and lots of patience (maybe an oven would help). It would look even more professional and create less aerodynamic drag, without a noticeable amount of lost "protection".
Just haven't gotten around to it with all the other projects I have going on.
Maybe next week when I'm on vacation.
I think the Lexan can be put in the oven to soften up and "lay over" a form.
I'll let you know how that works out.
Very solid.
Thanks
p.s. My instructable about homemade windshield
http://www.instructables.com/id/Easy-motorcycle-windshield/
Have you thought about figuring a way to form the plexi on a nice curve before installing it?
Shiny side up~
F5
I think my Vulcan will be getting a set of these this spring :)
I appreciate the comment.
