3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Motorcycle Saddlebags from Ammunition Cases
After pricing good waterproof saddlebags (panniers) that would fit my 2006 Kawasaki Vulcan 500 LTD, I just decided to do it myself and save some bucks.  Have you ever tried to find good waterproof storage for your motorcycle?  Did you find that they were a wee bit expensive?  Well, either you've done something similar to this instructable or you've sucked it up and threw your cash at some vendor.
What to do?  I found out that one of my hobbies helped with this - Geocaching.
Originally, I was going to put a few good caches around my area in ammo cases.  They're waterproof and if painted right, can be hard to find.  Since I was behind in putting the caches out there, I thought that ammo cases would be a great place to store small stuff on my bike.
Here is a picture of my '06 Vulcan 500.
Step 1Get some Ammo cases
Get some Ammo cases
Ammo cases are easy to find - Army Surplus stores, online, ebay, neighborhood militia group, etc...
I used a standard case for 7.62mm rounds.  They measured about 7in. x 3 ½ in. x 10 in.
What to check:  rubber gasket inside lid, rust, and latch.  Rusty, ok - just more work.  Rubber gasket must be intact and pliable.  Latch must work.  I think I paid $7 a piece for mine from a local Army Surplus store - and they had a ton of them.
Different sizes may work, but these seem to fit my motorcycle without hampering a passenger.
8 comments
Sep 6, 2011. 3:52 PMbadpanda says:
Great instructable, it inspired me to do something similar this past weekend I documented at http://www.instructables.com/id/Ammo-Can-Saddlebags/ and gave you full props for :)
Aug 5, 2011. 9:21 AMdeadeye says:
did the same thing on an old pan chopper i had back in the 70`s. used the box [only had 1 on one side] for a lawn mower battery. couldn`t close the lid so i roped it in. was running a total loss elec sys, non- funtional gen. you can see a few pics on oldmotorcycles blog by dan. R.T.
Jul 31, 2011. 3:27 AMrfreyhol says:
In the past I have also wrapped the top handles in leather using artificial sinew to "stitch" it together... it is still on there to this day and gets lots of use. Just a thought for dressing em up a bit more... Very good instructable!
Jul 26, 2011. 3:37 PMreptilehead says:
I've done this for years, a few suggestions for you:
use a piece of innertube rubber for the underside of the handle to keep the rattling down to a dull roar. same thing for the grab bar on the lock.
use rubber washers surrounding a stainless washer for additional space and scratch resistance on the fender supports (fender strut, rubber, stainless, rubber, can, rubber, stainless, bolt)
Adding pinstripes or led lights on the back will make it seem less utilitarian, and taking off the handles will help that as well. use a bolt cutter to cut the handle attachments.
plastic grocery bags work nicely as bag (box?) liners add a bit of additional waterproofing, not to mention make it easier to keep your gear clean and easy to get out!
great job!
Jul 26, 2011. 5:59 PMreptilehead says:
they really are tougher than you think, i laid my vstar down and had those on it. the bags took all the abuse and even the turn signals were kept intact (15 mph)
bent the bars straight, limped it home and put on the stock ones. back to riding again!
if anything i would make a way to keep it out of the spokes in the event of a laydown, the bars to "stiffen" the boxes i think is a bit overkill.
I think the next time i use these (i have a wicked 'fighter project coming up) ill put on some small red or amber LED lights for turnsignals and brake lights like the harleys use.
Jul 26, 2011. 4:44 PMknife141 says:
Excellent!! This is so much better than the overpriced plastic saddlebags that eventually start cracking at their mounting points. They look good, too. Great job!
Jul 26, 2011. 3:39 PMcombatbootboy says:
great idea! love the instructable
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:keltic88
Dad of 2 kids, husband of one wife, owned by 2 dogs. Programmer by day, builder/modder/tinkererer by night (and some weekends). Can we do it? Yes, we can!
