I played around with cardboard, tape, glue and marbles a lot as a kid, making tracks and ramps and such just for fun.
I had been wanting to make one of these for years, just to see what I could come up with now that I'm a little older. The main thing I'd been wondering about was how I could get the marbles back to the top with some sort of mechanism made from simple, available items.
The whole thing turned out pretty well, and surprisingly, the motor/conveyor belt system I came up with works perfectly, although the initial version was really fast (see the video in step 6).
I made a few changes to slow down the conveyor, and the final painted version is shown here.
Remove these ads by
Signing UpStep 1Supplies
I used lots hot glue, along with some wood glue and white glue in a few places.
Each side of the track is about 3/4 inch tall. I would draw out each new section of track on a sheet of cardboard, cut it out, and then match it up to an existing piece to see if it would fit on the track the way I wanted. These were like "trial" pieces. If the new piece worked well, and took the ball where I wanted it to go, I'd add the new piece permanently to the track, thus extending the track little by little.
If the new trial pieces didn't fit, which was the case most of the time, at least I could see specifically what shape the new pieces needed to be. Many times I would just try something--knowing that it probably wasn't going to work--but that it would show me what would.
Certain sections (like the loop) were completely made off of the the base, and then added as a finished unit.
This project took lots of trial and error, practice, and patience!
As for the paint, I brush painted everything with basic acrylic craft paints. The paint seemed to slow down the track somewhat, so I gave it a coat of lacquer spray, which helped speed things up, and gave it that glossy look you see.
I agree it would be cool to see how many marbles you could load this with.
I have a question. So did you just make the whole track first, then add it onto the structure, or build it as you went?
Thanks, this project looks awesome, I'm going to take it on soon.
Brings to mind my early (pre PC) days in the computer industry, when mice were a real novelty. IBM would only ever supply replacement mouse balls in pairs. I still haven't quite figured that one out....
http://www.micromark.com/MOTORIZED-PLANETARY-GEARBOX,8179.html
