Mountable Logitech C270
7,445
35
4
Posted in TechnologyUsb
Introduction: Mountable Logitech C270
To make a mountable Logitech c720 webcam (in this example: onto a Joby Gorillapod) you are going to need:
  • Power drill
  • Small Phillips Screw Driver
  • 2 1/4-20 in Hex Nuts (3 or 4 is not a bad idea)
  • 1 20 x 3/4 in Bolt. It should be at least 1" long. I used 3/4" in length
  • 1/4" drill bit
  • Super glue
Step 1: Remove Underneath Cover
Lay the webcam on it's back (screws pointing up). Open under cover fully. Remove the two screws highlighted in the picture. Remove that piece that the screws are holding in place.
There will be a metal weight on the inside of it. That can be discarded.
Step 2: Drill
The part that is still attached to the webcam, locate the center and drill a pilot hole from the inside through the plastic.
So as to not get confused, notice in the picture the black rubber pieces and where they are to get your bearings as to where the hole should be.
Once you are sure that this is the correct flip it over and drill through with the 1/4 drill bit.
Make sure that the bolt goes in and out of the hole easily, as it will be a tight fit otherwise for the mounting screw.
Step 3: Screw and Glue
Thread the bolt with one of the nuts most of the way.
Put some superglue on the underneath of nut (away from the top of the bolt) so as not to touch the threads of the bolt (just on the nut).
Push the bolt though the hole on the inside portion of the plastic until the nut pushed against the plastic. The glue should hold it in place.
Screw another nut through the other side of the plastic so as to sandwich the plastic tightly.
Add more superglue around the inside portion of the plastic, which you can see in the pictures.
Step 4: Remove Sandwich
Unscrew the nut that is not superglued and also unscrew the bolt.
This is shown in the pictures.
Step 5: Back Together
Reassemble the portion that you took apart.
Step 6: Done
All done. This can now be used as a mountable webcam
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    4 Comments
    Combining a mountable webcam with a Joby Gorillapod, like the one that I use here is awesome. Always purchase one with the magnets on the end of the feet to open up more possibilities, like sticking it to the corner of a wall.
    Worked great, thanks!
    good cams :) i have 2 for motion capture
    This is awesome! I love the idea of mounting a webcam!
