Mounting Solar Power Bank Without Bike Mount
Introduction: Mounting Solar Power Bank Without Bike Mount
This is an instructable of mounting solar power bank on bike using a rubber band.
Every time I've a rough ride, my bike mount usually fall off or worst.... broken!
The worst of all, what ever I attached on it will received the same fate (whether my smart phone or my power bank).
I'm sure you all have had a similar experience has I do.
This is my solution to the problem that I want to sharewith you.
Step 1: What You'll Need.
    1. 5000mAh Solar Power Bank ($19.99 at )
    2. A rubber band
    3. A bike
    Completion Time : 5 minutes
    Step 2: The Band
    Firstly, I located a part of the bike to place my solar power bank. I found it at the T joint handle bar.
    I took a rubber band and make a knot under the T joint handle bar.
    Carefully, I pull the rubber band around and up the front handle bar.
    Step 3: The Ties
    I insert the rubber band in the power bank's hole and stretch it (I broke a few rubber bands in this step, so ... do it extremely careful).
    Then, I spread the band so that its loop under the power bank.
    Step 4: The Secure
    The band is nearly stretch to the maximum (I broke another one.... :-( must do the process again).
    Then, finding a notch under the handle bar's joint, I finally secure the band.
    What a relief!
    Step 5: The Charging
    Now, what I'm waiting for?
    Let's go cycling!
    If I leave it outside or if I'm cycling in the day, the solar power bank will be automatically charged (indicate by the green light).
    Step 6: The Benefits
    If I double click the ON button, the power bank will on the LED light.
    Or, I can charge my smart phone.
    You don't have to worry about your phone's power run dry whenever you're cycling.
    Please don't forget to vote for me.
    If you like this 'ible, then please click 'Favorite' and 'Share' with your friends,
    If you've made this 'ible, then click 'I made It' to let me know,
    If you have anything to improve the documentation and to suggest an idea of improvement, then please leave a comment below,
    Please do subscribe my channel for future projects' updates.
    Thanks for giving an apt appraisal for my 'ible.
      • Pocket-Sized Contest
      • Science of Cooking
        Science of Cooking
      • Pro Tips Challenge
        Pro Tips Challenge
      Thanks for the gift.
      However, they don't sent to my country :(
      Free Gift - Portable Solar Power Bank 10000MAH Dual USB LED External Mobile Phone Battery Charger Backup
