These solid, simple frames require no exterior brace. This is perfect for apartment dwellers and those who only need an air conditioner a few months of the year. It takes about an hour and some basic lumber and tools to construct these frames. Once built, your air conditioner can be installed and uninstalled in minutes. (Please note that window air conditioning units aren't intended to be permanently installed. These frames also make it simpler to remove them at the end of the warm season.)
The units pictured include unfinished plywood. However, this can be finished, painted or replaced with plexiglass or other materials, as the sheet lumber simply covers an opening and is not structural.
YOU NEED:
2X4s *(2 or less but the amount varies)
12 deck screws (or other long wood screws)
Drill
Saw
Screwdriver
Plywood Scrap
- These window sills in the picture are fairly deep, allowing for the use of 2X4s. You may be able to substitute other lumber for shallower sills.
Remove these ads by
Signing UpStep 1: Take Measurements
Measure the height of your air conditioner. This height should be the box height and not include the lips on the bottom or the top.
Measure the height of the window opening. Take this measurement right up against the window because it will give the shortest height of this opening. (Again, mistakes reminded me that sills can angle away from the window, giving a height that is too long.)
Visit Our Store »
Go Pro Today »
I picked up the materials at my Local Home Depot and had the cuts made there as well. The only tools required were a drill to pre-drill the holes and a screwdriver. The entire project cost about $70, $45 of which went toward two sheets of plexiglass and mini blinds. The second sheet of plexi diverts drips from above.
Thanks for the great idea.
Photos attached.
starshipminivan do you have any suggestions? Thanks for your help or anyone else who has any ideas.
Also do you have to drill pilot holes beforehand?
It was a little more challenging because I only had warped 2x4's. Perhaps I got lucky because everything fit ok. Needed a little tweaking here & there.
My cross-piece in the center had to stick out a little toward the front to accommodate the A.C. unit. Stapling the screen to the back worked fine. I worked with some bracket steel and made little holders that the cover board slid into on the bottom, and fashioned some twist latches on the top corners to make installing and removing the board easier.
Thanks again. It is SO hot. The swamp cooler just doesn't work anymore. Now our bedroom is our little oasis.
I WOULD GLADLY PAY YOU TO HELP ME INSTALL MINE PERMANENTLY USING THE PLEXIGLASS.
THE WOOD AND OTHER STUFF IS TOO UGLY.
THANKS
CANDACE
Few a/c hacks are pretty, but when it's hot you do what you need to do to stay cool.
Sure, the Plexiglas looks nicer but I'm sure the cost is high on that.
I have the window brackets to hold my air conditioner in, but don't have a clue how to install properly. No instructions, purchased used.
Is there any way you could show how to do that?
I would really appreciate.
I can't even figure out how to remove the air conditioner from the case to install to the brackets first and then put the conditioner back into the case.
That is what a neighbour said they thought I should do.
I have searched for hours online looking for some kind of instruction with no luck.
Thanks for all your suggestions.
Laura
I also mentioned it in my little blog - http://rayvstheworld.com/2010/07/installing-a-standard-ac-unit-in-a-horizontally-slidingopening-window/.
Thanks for the help!
