Mounting a fan for solder fumes exhaust.
Taking a nice fan with a wierd base and mounting it to drywall above the Rock The Bike soldering station.
Step 1Create a wooden plate offset from wall for fan's triangle base to slip through.
Create a wooden plate offset from wall for fan\
11 comments
Sep 30, 2006. 3:16 AMFake_Name says:
That design would just blow the fumes around, not exhaust them. Solder fumes aren't too bad anyways. Fosin is just a sensitiser. If you have asthema, it'll make it worse. That's about it.
Nov 12, 2008. 12:36 PMBlackDidThis says:
Maybe I was just too stingy on my fan... since the technology was much more expensive those days...
But I always got a bigger headache from the fan than I get from the fumes.
Agreed, the sound is less harmful than the chemical; but my God did it drive me nuts!
(A Computer fan will possibly be my first project shall I start again)
Nov 12, 2006. 9:27 AMfluff says:
Solder fumes aren't bad? Unless you use lead free solder you're inhaling lead vapors. And don't tell me that is not bad. I agree that there is worse. But you should reconsider because this stuff accumulates...
Dec 15, 2008. 7:15 PMFake_Name says:
The vapor pressure of lead is *extremely* high, even at soldering temperatures. Lead fumes are not an issue.
As an experiment, when I was having some general-health blood tests done (cholesterol, etc...), I had them run a lead level test. Now, I've been soldering for perhaps 10 years, and a good portion of that was indoors, with less than ideal ventilation, and my lead level was so low the test didn't even register anything.
Dec 15, 2008. 6:02 PMosgeld says:
unless your vaporising lead, at like wat 800+ degrees F, and if your doing that you wouldn't be soldering much of anything... the most damage is caused by the flux fumes lead based solder uses rosin, which among other things has acids in it lead free solder doesnt, it uses much more agressive acids since it has to withstand the higher soldering temperature and still clean quickly before going up in smoke lead free fumes are actually worse, not as bad as good ol acid flux but not as "safe" as rosin
Dec 3, 2007. 10:04 PMalexanderm says:
lead-free solder is good, but you've still got the flux fumes, and the flux needed for lead-free is worse than what you can get away with using leaded solder. Get halogen-free solder. i vent my solder bench, but i have to admit that i sorta' kinda' like the scent of Kester 44. No, i don't go sniffing it!
Nov 21, 2010. 12:09 AMalexanderm says:
LOL! People make fun of me all the time for saying that! i, too, like the smell of Kester 44! And, no, i don't intentionally sniff it either!
Sorry for the bump!
Oct 21, 2006. 2:34 PMJordanZed says:
Yeah that will only move solder around. Get a computer fan, and tape it to a long tube (blowing into the tube). Then put the fan beside your soldering project and put the tube out a window. Ghetto but it should work :p
http://jordan.motivo.ca/img/lol.PNG
Sep 29, 2006. 7:41 AMjoddeye says:
you'd get a better fixing by omitting the washers with tinber srews there made to countersink right in
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:fossilfool
Fossil Fool, the Bike Rapper, a San Francisco street performer and bicycle entrepreneur. Invented the Down Low Glow, a neon safety light for bicycles. Develop high-end sound systems for bicycles used ...
more »
