Mounting a headlamp on a bikehelmet
 by nathanb
Everytime i use my mountainbike i hab the problem with the light. The dynamo ist nothing i really liked and i forgot many times my lamp which was mounted on the bar. It wasn't a good one, but if somebody has stolen it i had to buy a new one. After a while i used my headlamp under my bikehelmet but that wasn't so comfortable. So i thought about mounting my headlamp on my helmet.
Step 1: Fit holder for the headstrap
At first i chose a glue and plastic for the holder. test the glue on the plastic an on the helmet if the properties are ok. But just glue on the plastic part of the helmet, because the most glues inclues dissolver and it will destroy the styrofoam of your helmet.
Fit the holder on your helmets shape and test it at first by holding your lamp on your helmet. after you glued it on the helmet it is irrevesible.
shelory says: Jan 17, 2013. 11:39 AM
i just use zip ties and they work wonderfully. and when im don with the headlamp and want to put it away i just cut the zip tie. i even took off the strap.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
