Mounting Small Loudspeakers
7,137
109
10
Published
Introduction: Mounting Small Loudspeakers
The problem with small loudspeakers like these (this one is 50 mm - 2 inches - across) is that there is no mounting holes for fixing it to a baffle. I've devised a simple way of overcoming the problem.
Step 1: What You Need
1. Two eyelet screws (the kind you use to attach hanging wire to the back of picture frames).
2. A strip of stainless steel, salvaged from an old car windscreen wiper arm.
3. And of course your loudspeaker...
4. ...and the baffle you want to mount it on. I assume you've already made the right size of hole in it for your particular speaker.
Step 2: Use You Drill
Drill two holes in the baffle as shown in the picture, one size smaller than the thickness of the eyelet screws. I've found that 10 mm (3/8 inch) from the loudspeaker opening works for 50 mm (2 inch) speakers, and 15 mm (5/8 inch) works for 40 mm (1 and 5/8 inch) speakers.
Step 3: Screwing Time
Screw the two eyelet screws into the holes you've just made, so that their openings face each other.
Step 4: Now Do the Strip
Cut off a piece of the strip of stainless steel, a little bit longer (say 2 cm - 13/16 inch) than the distance between the eyelet screws. A side cutter works quite well.
Step 5: Fit It All Together
Push the strip of stainless steel through one eyelet, bend it over the loudspeaker, and pass the other end through the remaining eyelet. I've found that the loudspeaker is held quite securely. The speaker doesn't get damaged at all, and it is very easy to remove it again. If you're a bit paranoid, you can of course dab on a blob or two of silicone sealant to keep everything in place.
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
    10 Discussions
    I actually used two. The first one with the wires soldered on, is a 50 mm one, and the one actually mounted is a 40 mm one. Both are 3 watts and 4 ohms, and I got them from DX.com in China. The 50 mm one costs $2.88 (item no 118192), and the 40 mm one costs $3.25 (item no 122521). Both are quite highly rated by reviewers on the website.
    heat glue seemed to work fine as well. i am using the same speakers on my project. or almost the same ones. i have these sandwiched between a 3mm acrylic and a 3mm plywood sheet and fixed on with hotglue. :) but this seems like a good way to do it also. this makes it easier to change the speaker if you needed to.
    Tikka88, you're quite right. Heat glue will also work very well, and most hobbyists already have it in their arsenal. Thanks for the suggestion!
