Step 8Connect the cable
It is best to identify those wires using a multimeter, or some sort of continuity tester which will not damage the sensor chip.
Pin 3 of the sensor is the data in/out pin. It goes to the connector pin 12 directly, and to pin 5 via the diode.
Pin 4 of the sensor is the clock input. It goes directly to pin 9 of the connector.
Pin 6 of the sensor is ground. It connects to the large area of copper on the board, and to pin 25 of the connector.
Pin 7 of the sensor is the supply pin. It has to be supplied with +5 volts for the sensor to work. In the figure, this is the yellow wire, running back to a hard drive connector. If you have the original cable of the mouse, whether USB or PS/2, the five volt line will be present at the end. Just identify that and connect to it.
Add Comment
