Step 3Dissect (hardware) Mouse Part 2
Before you take things apart be sure to write down what wires go into what mounts on the circuit board so that you will be able to put things back together correctly.
Using a soldering iron, gently touch the tip of the iron to the ball of solder that holding the wire in place. After a second or two the solder will melt and the wire will come free. Leave the ball of solder attached to the circuit board - you can use it to re-attach the wires later on.
Add Comment
