loading
Step 4: Add the stick
 Carve a small stick that fits in your hand comfortably. It is a good idea to file down a rectangular block of wood, so you can attach a hinge to the bottom of the mouse. The hinge allows the user to shift his or her wrist angles. Stick the switch on a good spot of the stick where you can press it without getting in the way of writing. Stick the hinge to a uncluttered spot of the mouse base.
wow..thanks for the idea. <br>I have modified my mouse. <br>thanks to u. <br>http://www.youtube.com/watch?v=3zx5VFm6T8M&amp;feature=youtu.be
Potential.
Definitely.
Well... I've seen Microsoft Ball mice for $2 AU, and i'm buying a gigabyte GHOST mouse there. Might pick one up and give this a try. I think Ball mouse will work better and I'll try and compact it entirely to a pen-like structure. http://www.pccasegear.com/index.php?main_page=product_info&amp;cPath=258_697_698&amp;products_id=12375
have fun. there are two wheels with slots that spin with the ball ,and those are hard to move around.
That's what I was thining would be the hardest bit.
Ok, what if i just cut the mold to my likings? So i'll essentially have a circle of the mouse left? No?
That's an idea... To be honest I'm not really skilled with mice, but it'd be awesome if you did it!
Its only $2. I'll give it a go. I'll post results.
I would definitely choose an optical mouse over a ball mouse if you want to make a pen like thingy. The ball and associated little wheels and axles don't lend themselves well to any further miniaturization.
I'm not sure, I've never taken apart a mouse before. From the little I have seen, yes, it does seem a simple ball mouse would make an easier compact, vertical set up.
Very good, I want to add some enhancements: - Use a laptop mouse rather than the normal one, laptop mice are much smaller - Remove the chassis of the mouse and make your own smaller one - Remove the original mouse keys and fix them to the pencil. You can fix small pieces of metal on the top of the keys to make pressing them easier.
if someone is really good with electronics, they can take the optical sensor out of a optical mouse and put it at the end of a pen.
simple and really smart cool idea!!!!!!!!!!!!!!!!!!!!!
not as sensitive though
Its only hardware. Software tweaks will be needed, such as <strong>Changing the sensitivity in the OS. </strong>I think it is possible, I'll get back to you when I'm done.
I love it. I'll try it out tonight.
great idea!!
About This Instructable
19,354views
13favorites
License:
Bio: i like ice-cream.
More by ANDY!:Paper Ukulele LMFAO Robot/Shufflebot Head The Incredible Paper Canoe
Add instructable to:
