Step 12Wind up
iImage Information
Gently turn the back wheels backwards (if your unsure of the direction, put it on a surface and pull it backwards). When it starts to catch, lift the flap slightly and keep turning until the trap is starting to load. Keep going until it's pulled all the way back, then hitch it as one normally would setting a mouse trap (see instructions on package I guess).
Take a bit of care, because if the string snaps the trap will indeed close (quickly) and anything you have in the way will get hit. It's not exactly deadly, but not pleasant either - these things do pack enough power to make you go "Ouch".
This is your back axle. After putting it into place I used a bit of hot glue in two single bars to keep the axle from slipping back out of the eye holes. The original creator used bottle top tabs. Mine were too big and hit the wood, not allowing it to spin freely so I decided to abandon the bottle tabs and use a line of hot glue.. After I got the back axle in place, I tied the string to the flip bar- the thing that will snap back in place once you let go it (the thing that originally was used to hold the little mouse down to the wood).
To make your car run after you add the wheels, hold the snap bar back and roll the back axle up so the thread is wound around the back axle. When you let the mousetrap bar go, it will fling forward and pull the back axle incredibly fast. I discovered that undoing one side of the bar so that it was actually straight on one side made it FAR less scary to use :) Check out a couple of the other mousetrap cars to see their strings attached to long poles. That is the mousetrap bar opened on one side and bent straight. So it goes from a staple shape to an "L" shape. It works just as well, but seems less likely to nip the user.
Good luck.
Hope this helps. Let me know if you're still unclear. I will try to explain a different way.
mine does the same...What i did is i extended the cord and put an extra piece of wood on the end of the mouse trap. it worked perfectly.
so am i. cool. gobble gobble gobble. hi five
Yes!!!!!!!!!!!!!!!!!!!!!
