Mousebot is a simple bot that uses two "eyes" to sense light and then turns towards the light. A single large "whisker" is mounted on the front of the mouse to detect collisions. A collision with a wall will cause the mouse to reverse and turn then take off in another direction. This project is pretty cheap, if you have a mouse to use the other parts can be obtained for less than ten dollars.
If you have any questions or comments you can get me at jacob@makezine.com
Remove these ads by
Signing UpStep 1: Gather Materials and Tools
1 Ball Mouse
2 Small DC Motors
1 Toggle Switch
1 DPDT 5v Relay (Aromat DS2YE-S-DC5V works)
1 LM386 op-amp
1 2N3904 or PN2222 NPN Transistor
1 LED (any color)
1 1K Resistor
1 10K Resistor
1 100uF Electrolytic Capacitor
1 Audio Cassette Tape (you know, from the 80s...)
1 CD-ROM or Floppy Disk (for the bumper)
1 9V Battery Snap
1 9V Battery
2 or 3 Wide Rubber Bands
22 or 24 Gauge Wire (some stranded and some solid core)
TOOLS
Multimeter
Phillips screwdriver
Dremel
Small pliers
Wire cutter/stripper
Razor knife
Soldering iron
Desoldering tool of choice
Superglue or epoxy
Hot glue gun and glue
Hacksaw
Visit Our Store »
Go Pro Today »
I learned a lot from this project and it really got my interest up in BEAM bots.
You want one Double Pole Double Throw (DPDT) relay rated for 5VDC or two Single Pole Double Through (SPDT) relays rated for 5VDC.
You can purchase and appropriate 5V DPDT relay from Solarbotics or just read more about how they work on their site. http://solarbotics.com/products/re1/
Hope this helps.
Sincerely,
Christin Boyd
http://robotfun.wordpress.com
You can read about my experiments and how I determined that a 200 Ohm resistor resulted in my mouse moving in the straightest line on my blog.
-Christin Boyd
PLEASE HELP ME!!!!!!!!!!!
maybe like a schematic of something like that.
please respond ASAP! i am doing this for a science fair project and its due Monday!!!!! :0
Hey, I just finished mine but unfortunately it does not work. Don't know what I'm doing wrong... One motor spins real fast & the other spins really slow.
Thought I had done some wiring mistake the first time & re-wired the whole thing again, but still the same issue.
Any guess's, adding in a pic of what I have as if now though.
hoe do you make a simple robot without programming to follow light=(
=D
When the light level increases the resistance of the LDR drops causing the NPN transistor to turn on. The sensitivity of the circuit is set by the fixed resistor with a lower value needing a brighter light to turn on the motor.
The point in having the left ldr hooked up to the right motor and vice versa is so that when light falls on it the robot will turn towards the light until the intensity is the same and then drive forwards.
it only follows light
be cool if u could do this with a still working wireless mouse and have it still be able to opperate as a mouse :P
first i used a 32volt Electrolytic Capacitor ,but my battery was alwaysw dead.
with a 16 volt Electrolytic Capacitor th mousebot's battery has got a longer live.
both work....i hope i could help you jwoo2023
jaycar rules lol
i'm very new to robotics (and somewhat to electronics) and i ended up buying the wrong relay at radioshack (12v, not 5v). Is there any way to make this without the reverse mechanism circuit? i want it to be at the very least light seeking. I have been working on this for hours and I'm really frustrated... Later on I might find a relay to use and incorperate it but for now...?
whatever happened to radioshack?
but i really prefer going to a radioshack near me to physically buy it
that way i know im not getting broken equipment and besides im underage so i cant pay online through a credit card
but thanks for that
i don't found relay 5 volts
please help me what shal Ido?
please send to me
WBR - prabhu
There's a good deal of info in a Q and A format at
http://www.streettech.com/modules.php?op=modload&name=News&file=article&sid=1761
such as why we should use EMITTERS to DETECT light. It will blow your mind. :-)
This is the corrected circuit diagram of Mousey from the Make Magazine publishing.
http://www.allelectronics.com/make-a-store/item/RLY-504/5VDC-DPDT-DIP-RELAY/1.html
1 LM386 op-amp
1 LED (any color)
1 1K Resistor
1 10K Resistor
look like???
I have some old computer parts ( sound cards, video cards, floppy readers, cd readers, hard-drives) and i was wondering if i can scavenge any of these parts.
Help would be appreciated =)
The gray band on the capacitor is the negative side (voltage in I believe) and the transistor unless someone else knows a way to determine it... well, I would just go to the Shack with Radios (Radio Shack) and know you are getting the correct component. Actually the same with the op-amp seeing as it just happens to be one of the four IC's they carry. 1.29$ and .89c I believe.
Make Magazine Instructions
a 4.7V motor
can u use a DPDT 12v relay instead of the 5v relay?
https://www.solarbotics.com/products/abgm/
100uf Capacitor:
http://www.hobbyengineering.com/H1311.html
LM386 op-amp:
http://www.radioshack.com/product/index.jsp?productId=2062598
Toggle Switch:
http://www.radioshack.com/product/index.jsp?productId=2062495
Transistor:
http://www.radioshack.com/product/index.jsp?productId=2062609
1k Resistor:
http://www.radioshack.com/product/index.jsp?productId=2062343
10k Resistor:
http://www.radioshack.com/product/index.jsp?productId=2062347
Relay:
http://www.hobbyengineering.com/H2151.html
LED:
http://www.radioshack.com/product/index.jsp?productId=2062567
1 LM386 op-amp
1 LED (any color)
1 1K Resistor
1 10K Resistor
look like???
I have some old computer parts ( sound cards, video cards, floppy readers, CD readers, old mp3's, hard-drives) and i was wondering if i can scavenge any of these parts.
I have no knowledge of electronics and was wondering what these look like
5-amp DPDT mini relay. Coil: 12VDC, 60mA, 200 ohm. Contact/rating: DPDT, 5A/125VAC. Size: 11mm x 19mm x 13mm. CSA approved.
heres the link: http://www.thesourcecc.com/estore/Product.aspx?language=en-CA&catalog=Online&category=Relays&product=2750249
PS: barnes, i think its from asparagus =)
or refer to this link: Correct Circuit
http://www.vitacom.ro
GREAT IDEA and really good information from all of you on how best to complete. My 9 yr old son is really excited to build his first ROBOT. We have perfomed the neccessary operations on our Donor Mouse and are just about ready to begin the soldering...we've run into a problem. Ordered the 5v relay online and the pin layout does not match the one used in the schematic/directions above...I found our actual chip (NAIS TQ2-L-5v) layout online here: http://www.naisweb.com/e/relaye/mech_eng/mech_eng_tq/idahwex.html but not sure how to proceed. Anyone got the time to help a Dad in over his head??
Thanks in advance,
John
I made a different mouse with all new and different parts and it still goes in circles.
Any words of advice?
Hopefully that was somewhat understandable.
That would mean that the two pins two short are the pins next to the notch.
If you go to http://streettech.com/robotbook/circuitMousey.html there is a good schematic that shows the layout of the pins on the chip.
