3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mousebot Revisited
Mousebot Revisited
Mousebot from Make vol 2 is a fun introduction to robotics. So fun that I've created this expanded documentation of a Mousey build from start to finish, with a few extra little tips you won't find in the mag. This how-to is best understood after reading the original article from page 100 of Make vol 2 however it is probably not required.
Mousebot is a simple bot that uses two "eyes" to sense light and then turns towards the light. A single large "whisker" is mounted on the front of the mouse to detect collisions. A collision with a wall will cause the mouse to reverse and turn then take off in another direction. This project is pretty cheap, if you have a mouse to use the other parts can be obtained for less than ten dollars.
If you have any questions or comments you can get me at jacob@makezine.com
Step 1Gather Materials and Tools
MATERIALS
1 Ball Mouse
2 Small DC Motors
1 Toggle Switch
1 DPDT 5v Relay (Aromat DS2YE-S-DC5V works)
1 LM386 op-amp
1 2N3904 or PN2222 NPN Transistor
1 LED (any color)
1 1K Resistor
1 10K Resistor
1 100uF Electrolytic Capacitor
1 Audio Cassette Tape (you know, from the 80s...)
1 CD-ROM or Floppy Disk (for the bumper)
1 9V Battery Snap
1 9V Battery
2 or 3 Wide Rubber Bands
22 or 24 Gauge Wire (some stranded and some solid core)
TOOLS
Multimeter
Phillips screwdriver
Dremel
Small pliers
Wire cutter/stripper
Razor knife
Soldering iron
Desoldering tool of choice
Superglue or epoxy
Hot glue gun and glue
Hacksaw
442 comments
1-40 of 442next »
Mar 16, 2009. 9:06 AMblack9820 says:
Where shall i get LM386 in India Please suggest for it
May 7, 2012. 8:57 AMgunner2000 says:
sp road in bangalore
May 4, 2012. 4:59 AMJenowl says:
Hi, i plan to do this for my project. do you think you can provide me with the circuit diagram? It would be really great if i could hv the circuit diagram. pls help :)
Jun 8, 2010. 1:23 AMdany_11 says:
this instructable is very cool..i want to try this one..but i have a problem. i had only found a 6v relay and it only has 5 pins..PLEASE I NEED HELP
Jul 22, 2010. 8:56 AMhenrybot says:
the relay is for the backing-up movement of the mouse when it bumps to something so you can use that 5 pin relay for one motor only so instead of the robot backing up, it will just spins 'coz only one motor will reverse, here is my modified diagram of the mousebot. (and the corrected circuitry). i hope this will help you a lot.. Goodluck
Apr 24, 2012. 9:53 AMmr.future11 says:
well i did hav dpdt relay rather than spdt so was wondering how to connect 5 pronge. thank u very much for this.
Aug 23, 2010. 12:06 PMluudvig says:
I found it alot more esy to solder everything to a circuit board, here's a pic of my mousebot's brain.. :P
Apr 13, 2012. 7:24 AMkiran1997 says:
Dude thnx for ur Idea , i have my junkbot ready and running thnx man!!
Feb 17, 2012. 3:39 PMchessman908 says:
i just finished making this and it doesn't work! i have no idea what i am doing wrong, it could be anything!
PLEASE HELP ME!!!!!!!!!!!
maybe like a schematic of something like that.
please respond ASAP! i am doing this for a science fair project and its due Monday!!!!! :0
Feb 18, 2012. 10:11 AMchessman908 says:
......................or a circuit?
Feb 19, 2012. 10:37 AMchessman908 says:
never mind i found something
Jan 24, 2012. 5:08 PMkidkid108 says:
how much will this cost in all?
Jun 5, 2011. 3:55 PMtoxiq2011 says:
Hey, I just finished mine but unfortunately it does not work. Don't know what I'm doing wrong... One motor spins real fast & the other spins really slow.
Thought I had done some wiring mistake the first time & re-wired the whole thing again, but still the same issue.
Any guess's, adding in a pic of what I have as if now though.
Dec 22, 2011. 8:26 AMVapolord says:
hey dude i had the sam problem; once he had a circuit here and its different from the stuff he tells u; search for the circuit, it might be in the pdf
Nov 5, 2011. 8:15 PMmr.future11 says:
i mthe beginner of electronics student. can i be helped by anybody of following members who hav tried this project. i would great thankful 2 him or her
Jul 29, 2011. 8:16 PMms10 says:
its a very cool project simple and great can you tell me where did you get all those things
Jun 13, 2011. 6:20 AMfluffybunnys123 says:
hi I can't find the lm386 chip but have a tda2822m. is this alright to use instead???
Oct 26, 2010. 7:52 PMsparkspooky says:
PLEASE ANSWER...ANYBODY
hoe do you make a simple robot without programming to follow light=(
=D
May 30, 2011. 3:17 AMdaliad100 says:
A circuit like this should do the trick although you will almost certainly want some bigger transistors/ darlingtons.
When the light level increases the resistance of the LDR drops causing the NPN transistor to turn on. The sensitivity of the circuit is set by the fixed resistor with a lower value needing a brighter light to turn on the motor.
The point in having the left ldr hooked up to the right motor and vice versa is so that when light falls on it the robot will turn towards the light until the intensity is the same and then drive forwards.
May 29, 2011. 7:44 PMThe nerdling says:
i might post how to post it it is really simple
Apr 10, 2011. 2:20 AMjwoo2023 says:
just make a robot going forward or open up a tennis ball and put a vibrobot in to it then it will move around.
May 29, 2011. 10:40 PMilpug says:
so, this is basically the same exact thing as the Herbie The Mouse-bot kit by SolarBotics, but built inside a computer mouse?
May 29, 2011. 7:43 PMThe nerdling says:
i know how to make a really simple one with two photo resistors and motors.
it only follows light
May 16, 2011. 12:40 AMthelastonekills says:
hi, this is a good idea, 5/5
be cool if u could do this with a still working wireless mouse and have it still be able to opperate as a mouse :P
May 15, 2011. 8:39 PMR.A.T.M says:
what voltage is the mortors
Apr 12, 2009. 3:35 PMcartilige says:
I'm busy making a different project, but it requires a lot of similar components. I am looking for a LM386 op-amp but I'm finding it very hard to get, any ideas where I could get one. DO NOT SAY RADIO SHACK. I live in the UK and can't travel very far from Newcastle so where could I get one, if it is used in any household products I have aces to a whole range of them which I can strip down. Thanks
Apr 10, 2011. 8:00 PMjwoo2023 says:
maybe a amplifier? strip it down and try to find one!
Apr 14, 2011. 2:26 AMavishadur says:
some stores (I don't know what equivalent of jaycar is in england, maybe they have one) will mail your components out to you so it can be just a matter of searching electronics hobby stores in the UK and checking if they mail out to you.
Sep 18, 2009. 5:02 AMcoleyy says:
Feb 28, 2010. 3:33 PMthestyrofoampeanut says:
 you are retarted
Dec 22, 2009. 12:50 AMmagiccowy says:
jesus read what he wrote before you comment he said HE DOESNT LIVE NEAR ONE
Jan 7, 2010. 4:43 PMmilsorgen says:
whoosh
Aug 6, 2009. 8:19 AMMelonSponge says:
maplin
Jul 15, 2009. 12:41 PMrobomaniac says:
go at radio shack man!
Jul 12, 2009. 6:45 AMmmattson says:
soundcard, modem, most devices that have an audio compononent. LM-386 is an audio amplifier.
Jan 28, 2010. 1:55 AMmagiccowy says:
+ is always the longer wire but look inside the actual thing and the smaller one is the anode (+) the larger one above it is the cathode (-) hope that helps
Apr 10, 2011. 8:01 PMjwoo2023 says:
thankyou very very very very very very much!
Jan 27, 2010. 11:33 PMjwoo2023 says:
Is the a mark?
Apr 10, 2011. 4:07 AMjwoo2023 says:
wow thanks a lot
Nov 5, 2009. 2:48 PMVapolord says:
i bulit this mousebot.
first i used a 32volt Electrolytic Capacitor ,but my battery was alwaysw dead.
with a 16 volt Electrolytic Capacitor th mousebot's battery has got a longer live.
both work....i hope i could help you jwoo2023
1-40 of 442next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:m_jake
