Step 6Install the bump switch
Connect the resistor on the switch to the base (middle pin) of the transistor and the wire from the ground side of the capacitor to the - voltage rail. Then connect the middle pin to the + voltage rail. To make your joints a bit more secure you can use heat shrink tubing to insulate the connections and bend the capacitor to the side to free up a little bit more space.
first i used a 32volt Electrolytic Capacitor ,but my battery was alwaysw dead.
with a 16 volt Electrolytic Capacitor th mousebot's battery has got a longer live.
both work....i hope i could help you jwoo2023
