3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mousebot Revisited
Step 8Construct Mousebots top half
First drill three small holes at the front of the mouse for the two eyes and sensitivity boosting LED. Then drill a larger hole for your toggle switch at the back of the mouse and install the switch to form mousebots on/off tail.
To create mousebots eyestalks twist two pieces of solid core wire together and solder the IR emitter to the leads on one end. Place the LED in the middle hole and connect the + lead to the 1k resistor.
Next use the diode check feature of your multimeter to find the - leads of the IR emitters and connect them to the - lead of the LED.
5 comments
Jan 28, 2010. 1:55 AMmagiccowy says:
+ is always the longer wire but look inside the actual thing and the smaller one is the anode (+) the larger one above it is the cathode (-) hope that helps
Apr 10, 2011. 8:01 PMjwoo2023 says:
thankyou very very very very very very much!
Jan 27, 2010. 11:33 PMjwoo2023 says:
Is the a mark?
Apr 10, 2011. 4:07 AMjwoo2023 says:
wow thanks a lot
Feb 10, 2010. 8:15 AMMudbud says:
yeah I agree with magiccowy.  you can use that techneec for all LEDs
Jan 27, 2010. 11:32 PMjwoo2023 says:
how do you know which side is + and - on the infra red emmitors?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:m_jake
