3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mousetrap Car Racer
Mousetrap Car Racer
Recently in Physical Science, we were assigned to construct a mousetrap-powered car.  After a great deal of research, I had a basic idea of what I wanted to make.  The end result is what you see.  This mouse trap car is more for speed than for distance, although it's performance seems to be between the two.  It goes a decent distance, and it travels at a decent speed.  While being lightweight, This car is also quite sturdy.  It's fairly easy to make, so give it a shot if you're interested!
Step 1Materials
Materials
There are a few specific items that you'll need for this project, but you can probably use similar items if you aren't able to find balsa wood, copper tubing, etc. in the sizes that I used.  So, here's what you'll need for the project:
* 1 Victor mousetrap
* 1 pool noodle (try to get one with an inner hole that has a small diameter)
* 1 long piece of balsa wood (You will need two 8" lengths of this balsa wood.  I cut mine from one piece of balsa wood that was 1/4" thick and 1" wide)
* slender copper tubing (the diameter of mine was 5/32", but you can use a close size)
* 4 small screw nuts (these must fit over your copper tubing, ideally as close a fit as possible)
* 1 wing nut (like the others, this nut must also fit over your copper tubing)
* JB-Weld
* wood glue
* electrical tape
* string, yarn, twine, etc. (just make sure you can tie it and that it can wind easily)
* (optional) corner braces or similar item (as many as needed--I used two)
Tools:
* a pair of pliers
* hacksaw or knife (to cut pool noodle with)
* (optional) miter box (for clean, square cuts when you cut the pool noodle)
* pipe cutters or something else to cut copper tubing
18 comments
Apr 6, 2012. 2:38 PMbergiemoore says:
That's a LOT of electrical tape (not to mention time.) Do you think putting a wade of hot glue there and attaching the wheels would work? Or paper that was glued? I haven't made your car, so I'm asking if you think something else than e.t would work.
Apr 1, 2012. 7:44 PMtornagen says:
great idea!
Mar 30, 2012. 4:31 PMpenglish1 says:
Can you list all the materials that i need because im going to the store Monday thanks!
Dec 16, 2009. 7:59 PMMadrias357 says:
Mousetrap cars are fun!  I remember doing this for our Physical Science class, along with Newton's Third Law of Motion a week later with rubber band powered fan cars.
The only problem was our class was very immature and took instead to leaving the mousetraps (our last step of installing) in people's chairs or on desks so we'd snap ourselves with them.
Dec 25, 2009. 7:42 PMMadrias357 says:
I was the first to get my hand stuck in one.
Mar 11, 2010. 7:01 PMpieman12 says:
ow...
Jul 26, 2011. 5:27 PMbraneyy says:
can you please help me with a mouse trap car with skateboard wheels i don't know how to move it and its due on friday please reply by tommorow THANKS!
Jun 20, 2011. 6:35 PMpeaceandlove says:
Is fast this car?
Mar 21, 2011. 12:52 PMaliceisavamp says:
This car is not a car for a poor persona
Mar 21, 2011. 12:53 PMaliceisavamp says:
bye bye bye
Dec 29, 2010. 3:19 PMBashful Brunette says:
How far did your mouse trap car travel????
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:geek27
I'm Alec. I like to post Instructables whenever I get to work on my own projects. But, that isn't exactly all the time. I usually find myself pretty busy with school, so it's not often that I actua...
more »
