loading
Step 8: Decoration (The Best Part!)
Finally, the actual fun part of making a mousetrap car: decoration!  You can probably tell that I had fun with mine!
<p>does this mouse trap car 100% work and how far does it travel?</p>
<p>your mom</p>
<p>why copper tubing and can u use something other than it</p>
<p>-_-</p><p>You can use anything you want, from PVC tubing to pencils lol. Axle thickness is what you should be looking for.</p>
<p>sry geek27 for all the people with joulous issues and put you down you did a great job ???</p>
<p>wow great job can u please pm me the meat rails best to use that would be awesome I'm doing a 6th grade project and need you to pm me asap</p>
<p>Where did you get the pictures? I know Google images? Or something. And what worked best when attaching the bolts onto the axels, glue or electrical tape? One more question, why did you name it &quot;The Obese Gopher&quot; ? And where did you make it? </p><p>If you could try to answer me, that would be great!! I'm doing this for an 8th grade science project and the model looked innovative and creative to me.</p>
<p>Could you please attach verbal instructions for Step 3? I have to make a car for a project at school, and this is one of the best designs I've found so far..</p>
<p>And for #5 as well...sorry and thank you!</p>
<p>string, yarn, twine, etc. (just make sure you can tie it and that it can wind easily) if u could estimate how much would you need</p>
<p>where did you buy all the supplies from? Trying to make this for my project! That's in 2 weeks </p>
<p>How long did it take you to make this car?</p>
<p>Since I made this years ago, I can't remember now how long it took! But, if I were to estimate, I'd say you could probably make this in a couple hours' time if you had the materials and the instructions (of course, you would need to wait for the glue to dry, though)</p>
<p>Really well done! This is the best design I've found so far. My son has to make one for a D&amp;T project and we're going to try your design. I'll let you know how it goes!!!</p>
That's a LOT of electrical tape (not to mention time.) Do you think putting a wade of hot glue there and attaching the wheels would work? Or paper that was glued? I haven't made your car, so I'm asking if you think something else than e.t would work.
I wouldn't think that hot glue would work very well--you'd probably make quite a mess, you'd be rushing to glob on all the hot glue, and once you stick the wheel on, it probably won't be centered with the axle. That means that when you finish all four, the wheels will be crooked on the axles and your car won't work as well.<br><br>Paper might work if you make sure that it's glued to the axle well. Really, the point of using electrical tape is to build up the diameter of the axle so that the wheels fit snugly. Electrical tape is convenient because is will probably never come off your axle unless you peel at the end of it. Using paper would bulk up the diameter of the axle evenly, but it might be harder if you work with glue instead of using electrical tape.<br><br>So, unless using electrical tape is too expensive, that's what I would recommend. I don't remember using too much electrical tape when I did this project--certainly not an entire roll. It might look like more than it really is, since the diameter of the axle is quite small compared to the diameter of the roll that the tape comes on.
great idea!
Can you list all the materials that i need because im going to the store Monday thanks!
At first, I was going to ask you to check my step that lists the materials, then I looked at it, and the horror sunk in--<br> <br> I have no idea when this happened!&nbsp; Apparently, I deleted all of the text that I wrote for steps 1, 3, and 5.&nbsp; Now, I'm not sure if I'll be able to rewrite these or if I'll be able to get back to you quickly, because I'm really, <em>very</em> busy this weekend.&nbsp; But, I'll try--thanks for pointing it out!
Mousetrap cars are fun!&nbsp; I remember doing this for our Physical Science class, along with Newton's Third Law of Motion a week later with rubber band powered fan cars.<br /> <br /> The only problem was our class was very immature and took instead to leaving the mousetraps (our last step of installing) in people's chairs or on desks so we'd snap ourselves with them.<br />
Ah, thanks for being the first one to comment!&nbsp; Of course, that happened in our class too.&nbsp; People would plant mousetraps under other people's binders.&nbsp; I suppose it is to be expected though... fun anyways!<br />
I was the first to get my hand stuck in one.<br />
ow...
can you please help me with a mouse trap car with skateboard wheels i don't know how to move it and its due on friday please reply by tommorow THANKS!
Sorry, I usually try to reply to my messages quickly, but I just got home from vacation, and I didn't have access to a computer for the past week.<br><br>This car was built to be pretty light. The body's made out of balsa wood, and the wheels are made out of foam pool noodle. I haven't held a skateboard wheel all on its own, but I imagine that it's pretty heavy, or at least considerably heavier than foam noodle. The mousetrap might not have had enough power to move the heavier skateboard wheels.<br><br>Sorry I couldn't get back sooner!
Is fast this car?
Well, I'm having a hard time comparing my mousetrap car's speed to the speeds of other mousetrap cars since I did this project (and researched other mousetrap cars) a little more than a year ago. I wrote to another user:<br> <br> &quot;But, I could give you an estimate of how far it traveled. The goal of the school project was that the mousetrap cars travel at least ten feet. I know that my car went ten feet easily, and consistently. However, it didn't go much farther. I would estimate that the maximum distance it went would be around 15-20 feet.&quot;<br> <br> So, obviously, the mousetrap car didn't really travel <em>that far</em>.&nbsp; I don't think that it necessarily slowed down a lot either, so I'm pretty sure that it didn't get going that fast.&nbsp; I had meant for it to accelerate fairly quickly (as opposed to making it go a great distance), and I think that it went decently fast.&nbsp; It is a bit faster than all of those &quot;distance&quot; mousetrap cars, though.<br>
This car is not a car for a poor persona
I'm going to guess that what you just said is a compliment and say, &quot;HECK NO IT AIN'T FOR A POOR PERSONA!&quot;
bye bye bye
How far did your mouse trap car travel????
Unfortunately, I never got to measure that. I was planning on it, but I ended up turning my car in (it was for a school project) and never getting it back...<br> <br> But, I <em>could</em> give you an estimate of how far it traveled.&nbsp; The goal of the school project was that the mousetrap cars travel at least ten feet.&nbsp; I know that my car went ten feet easily, and consistently.&nbsp; However, it didn't go much farther.&nbsp; I would estimate that the maximum distance it went would be around 15-20 feet.<br> <br> That distance really isn't all that impressive compared to many mousetrap cars you can find on the internet, but it got the job done, which was to go only 10 feet.<br>
About This Instructable
209,174views
68favorites
License:
Bio: I'm Alec. I like to post Instructables whenever I get to work on my own projects. But, that isn't exactly all the time ... More »
More by geek27:Mousetrap Car Racer Nerf Mods: A Beginner's Guide
Add instructable to:
