3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Movable record player greeting card from a floppy disk
  • last photo ←
The actual disk part of an old 3.5" floppy disk looks suspiciously like a record, doesn't it? It only takes a few minutes to turn one into this personalized turntable greeting card. The best part is that the card is assembled with brads so the record spins and the player arm moves, too. Perfect for audiophiles and geeks alike.
Step 1Assemble your materials
For this project you'll need:
- an old 3.5" floppy disk
- a flathead screwdriver
- scissors
- hole punches
- blank greeting cards or cardstock to make your own
- small brads
- cardstock or corrugated paper for the record player arm
- embellishment items: stamps, collage paper, glue stick, etc.
If you don't have 3.5" floppy disks of your own, try a local second-hand store. In the Portland, OR, area both SCRAP and Free Geek usually have them for 25 cents or less apiece.
38 comments
Oct 14, 2009. 5:20 AMModMischief says:
Awesome instructable!
Thanks for posting it.
Here's the one I made: http://modmischief.blogspot.com/2009/10/you-spin-me-round.html
Sep 15, 2009. 5:35 AMGoodhart says:
What would make this VERY cool project even cooler, would be to go and get a few (one for each card, you need) cards that have the circuitry within them to play back something you've recorded on them (by pressing the right mini button and speaking, or playing music). I have seen them in some discount stores, so they can be had for cheap - around a $1 or 2 (compared to buying a Radio Slack voice module that is both too big and way too expensive, and really doesn't sound good either, for nearly $20).
You could then use the activating strip from the bought card AND the voice recorder/playback module in your card and the record would sound like it plays ;-)
Sep 24, 2009. 6:23 AMGoodhart says:
The only drawback is time. If you have only a few (5-10) passwords, they may fit, otherwise one would have to have more than one or try to find a small digital voice recorder circuit that records more. Radio Shack, at one time, sold the chip and you could build a small circuit around it; but they no longer sell that, and the kit they now sell isn't worth buying, unless you don't mind adding an amplifier circuit to the thing. :-)
May 4, 2009. 8:22 PMAmdivns says:
Hey guys, imagine a gramophone player, but in reverse. I made a smaller gramophone recorder and used an old Mc donald's windup toy as the power source by talking (loudly) into the cone. The vibrations travel down the cone to the needle (slightly sharpened) and become etchings on the floppy disk. Still writing the instructable, will be up soon!
Jun 30, 2009. 3:44 PMamplex says:
wow, always wondered how i could do this !!!!! please post!!!
Apr 14, 2009. 1:21 PMfwjs28 says:
WOW!.that is amazing
Apr 29, 2009. 4:01 PMelleadnih says:
this is awesome I am gonna do one!
Apr 25, 2009. 11:28 PMDJShmeeejay says:
VERY, VERY COOL !
Apr 21, 2009. 9:46 PMFeedTheGrid says:
Very cool. If I find all of those old floppies; now I know what to do with them! FTG
Apr 20, 2009. 8:34 PMAmdivns says:
I managed to make an actual working record card what you need is to make a stationary metal cone (basic microphone) connected to a sharp needle which will drag along a slowly spinning disc of plastic or wax, thin aluminium (I used the floppy). create a disc that when you pur a blunt sewing needle into a paper cone the system works backwards and plays the sound (which is the bumps in the metal. I will post an instructable on how to do this shortly
Apr 21, 2009. 6:21 PMmortso says:
Do post it, that's a very cool project and reaches into the Mind of Thomas Edison!
Apr 20, 2009. 11:39 PMshiboohi says:
wow sounds pretty complicated. how did you figure all of that out?
Apr 21, 2009. 6:20 PMmortso says:
You should be able to use the head from a disk reader and actually record Audio onto the floppy disk. It's just recording frequency instead of Data. Then when you spin the disk you'd get sound. Think of it as a circular tape machine.
Apr 19, 2009. 1:52 AMshiboohi says:
really great instructable! i used a button and a metal sharpie pin for the needle, also i added one of those music players from a musical card and it played when you spin the wheel. you are very creative :) pretty awesome!
Apr 20, 2009. 9:31 PMshiboohi says:
well when the music player is in the card it plays when it is opened and it pulls on a tab, so i just cut a slot through the bottom of the card and taped the tab to the record and boom! there you go :)
Apr 16, 2009. 3:15 PMNimphious says:
How about combining this idea with paper gears, and have the arm rotate when you spin the record? You'd have it geared down, say 20:1, so that you notice it's movement, but you can still spin the record quite a bit before having to go backwards to return the arm. Could also be a good excuse to remove the metal portion of the floppy magnetic disc, and replace it with a paper disc with their favourite song's album printed on it. If you were bored/ambitious enough, you could probably combine this with a little sound-chip from some random greeting card, and have it activated when the arm rotates past a certain point.
Apr 19, 2009. 1:56 AMshiboohi says:
those sound like great ideas but the point of this instructable is to make a cool greeting card with minimal effort (thus the use of floppy disc).
Apr 16, 2009. 5:48 PMWhyIsThisOpen says:
I would rank paper gears as more bored/ambitious than using a part from another greeting card.
Apr 17, 2009. 3:13 PMcontrolledwrinkles says:
I've seen this http://www.wikihow.com/Make-a-Starship-Enterprise-out-of-a-Floppy-Disk done in the past and it was a wee bit too geeky to ignore. And I've made quite a few of these things for fun and as Christmas decorations: http://www.flickr.com/photos/13706164@N04/3451357348/
Apr 16, 2009. 6:38 PMT-K says:
AWESOME!! I am a DJ aspirant (you could call me that, or wannabe), so I hope i get this card for my birthday. But then it wouldn't be so exciting anymore. Damn. But still, an awesome idea! This is a great way to reuse them.
Apr 16, 2009. 8:48 AMNoBonus says:
I made this one at the office... we had no card stock so I cut the arm from an old business card and cut down a trashed manilla folder for the "card stock" Turned out beautifully! Nice instructable! One of my all time favs! Also, my beautiful spouse really enjoy receiving such a cool card (it is currently up on the fridge!) THANK YOU!
Apr 16, 2009. 7:08 AMnilmahj says:
This is absolutely GREAT! It would be cool to print out mini record labels (round stickers) with the recipients name as the artist of the album, and the name of a song that describes something that person likes. Very cool 'ible. 5 thumbs up. (stars)
Apr 16, 2009. 10:00 AMNekayah says:
Yes, but how do you put sound on the disk, or is it just for text or images?
Apr 16, 2009. 9:29 AMveganboyjosh says:
with a little more setup and planning, you could also write words which are hidden and show through the little window in the silver part of the disc as you spin it. nice looking piece.
Apr 16, 2009. 9:12 AMthehonestape says:
Very awesome! Might have to use this for some packaging projects I have in the works. Thanks.
Apr 16, 2009. 8:31 AMpravardhan says:
Very Good idea of utilizing old and bad sectored floppies into goodies.
Apr 14, 2009. 7:39 AMrimar2000 says:
The player arm (pick-up) has an angle, to enhance the tangency.
You can see this at http://tecnotrekos.blogtvespana.es/img/Image/Tecnotrekos/2008/janeiro/numark_tti_opt.jpg
Apr 14, 2009. 12:29 PMmweston says:
I think the simplicity is what it is about, but if you really wanted to add an angle, i would only put the last inch at a 30-ish degree like the older style record players. Thats only my opinion though.... Good project BuildMakeCraftBake too!
Apr 15, 2009. 9:37 AMelenilla says:
sweet!
Apr 14, 2009. 4:27 PMLinuxH4x0r says:
AWESOME! 5/5
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:BuildMakeCraftBake
