Mower Kicks Back--Replace the Flywheel Key
 by Phil B
Featured
Step 8: Install flywheel
Place the flywheel on the crankshaft. It should slide down smoothly over the new key. Oil the threads on the end of the crankshaft. Place the cup, the washer, and the nut onto the crankshaft. Begin to tighten. Never pry against the flywheel cooling fins. They break easily. Turn the flywheel a couple of times to make certain it turns smoothly and nothing is obstructing it. If you did not tie back the dead man's clutch, you will hear a terrible scraping sound. Torque the flywheel nut. The recommended specifications are usually around 33 foot pounds. On some engines the figure will be 35 or 39 foot pounds. In general, if you are shearing a lot of flywheel keys for no reason, the nut is not yet tight enough.
Bryan Smith says: Sep 28, 2010. 8:12 PM
The part of the crank shaft that the flywheel touches should be clean and dry.
I got some oil on mine and the key sheared again when I mowed over a stick. spraying on some brake cleaner got the misplaced oil out when replacing the key for the second time. I agree that the threads for the nut need oil sparingly.
Phil B (author) in reply to Bryan SmithSep 29, 2010. 6:42 AM
Your comment makes a lot of sense. The flywheel is held in place by a compression fit on the tapered shaft. Oil would have the effect of making the fit less secure. The key really has very little holding power. Thank you for the comment.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
