Step 3I would like the number 7, please. Yes, the hard drive platter with extra ketchup.
In this mod you will pry off the hard drive's solid exoskeloten, exposing the raw pink flesh inside (im making myself hungry). The photos for this kind of suck due to the reflection comming off the platter, oh well.
Before you start have a sealable plastic freezer bag near by to shove it in once you remove the cover. If one single piece of dust gets on the platter it could kill your drive, at least thats what I read, although once I finished this I saw some particles had gotten in, but it still worked fine. To make the window you will need a plastic cd case, I decided to go with clear because it would give me the best visibility, but you can use one of the colored jewel cases too. Oh and make sure the plastic does not have scratches on it, thats something I overlooked and now regret.
Measure out the size of the hard drive onto the plastic case. To cut it I used a razor and scratched each line deep into the plastic, and when I felt it was deep enough I snapped the piece out (the first one I tried cracked from this method, so make sure that you cut really deep with the razor). Once you have the window you are ready to unscrew the hard drive cover.
Unscrew the screws from the hard drive cover, put the entire hard drive in the freezer bag, and remove the cover. You can attatch the window in a number of different ways. The first thing I tried, and failed, was drilling the screw holes through the plastic and trying to screw it on. The reason this didnt work was because the metal cover I removed wasnt flush with where it was screwed on, it actually had an raised surface where the spindle was (like most hard drives do). So to fix this problem I put the screws into the hard drive, but did not screw them in all the way, this way they acted as risers, and lifted the plastic far enough off so that it wasnt touching anything inside. However, this didnt hold the plastic on, and there was a big gap between the plastic and the hard drive case. To solve that problem I filled the gap with Devcon multi purpose glue.
When putting the glue on, you have to be absolutely certain that none drips down inside of the hard drive, to do this I suggest you use only a small amount at first, and after you apply it flip the case over so it is resting on the plastic, this will prevent the glue from dripping towards the inner workings. Once the first amount dries, you can apply more glue to make it air tight, also let this glue dry when the harddrive is resting on the plastic side.
When it dries go show it off to your friends, they will be able to see the platter spinning and the arm moving back an fourth picking up your 0's and 1's and turning them into music.
14
comments
Add Comment
hivoltage
says:
Add Comment
