3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mp4 charger
Mp4 charger
The charger is very simple is based on a lm340t5 but you can use a 7805 cip!!Wat I used i haved laing arownd in my most circuits I'm traybg to recicle parts from browken electronics!!Sory abous the bad spelling englis is not my language ,but if I rowt in romanian you wodent andestand a fing!!
Step 1The product
The product
  • C:\Documents and Settings\Ovidiu\Desktop\New Folder\Image081.jpg
  • C:\Documents and Settings\Ovidiu\Desktop\New Folder\Image082.jpg
  • C:\Documents and Settings\Ovidiu\Desktop\New Folder\Image080.jpg
  • C:\Documents and Settings\Ovidiu\Desktop\New Folder\Image084.jpg
  • C:\Documents and Settings\Ovidiu\Desktop\New Folder\Image087.jpg
  • C:\Documents and Settings\Ovidiu\Desktop\New Folder\Image085.jpg
Sory abouwt the few instructables but tray to maket laik you wanted!! I used hot glu to stic all the parts to gheter!!
4 comments
Apr 7, 2011. 10:50 AMTrelligan says:
A diode on the output of the regulator helps protect the circuit and the phone. If you plugged in the charger and the battery were missing or low, the phone would discharge into the charger. +5V power feeding back into the regulator chip will probably cause no harm, but would be a waste of a phone's charge.
Use a Schottky diode so your precious battery juice isn't wasted warming up a cheaper diode.
A small capacitor (0.1 uF) after the diode will help protect delicate equipment from switching transients. These can happen if you connect the charger, then change the battery while still connected.
Dec 13, 2009. 9:17 PMimakethings says:
do i need to use a diode  with the LM7085 voltage regulator
Nov 29, 2008. 11:26 AMalex-sharetskiy says:
Hey, if you can, please re-do this insturctable, some people need to "see" how the lm7805 is soldered! thanks!
Apr 23, 2009. 8:46 PMfurcino says:
what do you want to see :) ? just look up a datasheet on the web. this is the default setup.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:dj_oracol
