Mr. Buzz, the USB Solar Charger in a Cup by Gadget Gangster
Featured
Mr. Buzz is a solar powered USB charger in a cup! The lightweight and flexible PowerFilm solar panel charges up the 2400mA battery pack so you can recharge your USB device even without the sun.
What's so cool about Mr. Buzz?
  • Uses flexible solar panels that are extremely light, unbreakable and can be mounted on nearly anything.
  • Rechargeable batteries in the cup let you charge / power your device even if the sun isn't out.
  • Total power storage of around 2,500 mA, more than enough for a full iPhone recharge, or multiple recharges for smaller devices, like a shuffle.
  • Has a USB 'Type A' jack, the same jack that's on your computer, so you can connect to any USB device.
Mr. Buzz is available as a kit from Gadget Gangster.
Step 1: FAQ
What is Mr. Buzz?
Mr. Buzz is a solar powered USB charger. A flexible solar panel (PowerFilm) is used to charge Nimh batteries, so Mr. Buzz can charge up your USB device even if there isn't any sun.
What can I charge with it?
Mr. Buzz uses a 'Type A' USB Jack, the same style USB jack that's on your computer, so it will physically connect to nearly any USB device. That said, some devices don't like being charged by a battery pack or solar panel.
Usually, if you plug your device into your computer and it needs to install software before it begins charging, it will not work. Here's what I've tested:
WORKS:
Apple iPod: Mini, Nano, Shuffle 1G/2G, Classic, Touch, iPhone
Creative Zen Micro
Nintendo DS (with an adapter cable)
Microsoft Zune
ATT Fuze, aka Touch Pro
Motorola S9-HD
PS3 Bluetooth Headset (in holder)
Verizon PPC 6700 (HTC Apache)
Creative Vado
Creative Zen Stone
DOESN'T WORK:
So far, any device that doesn't work with my usb wall charger will also not work with Mr. Buzz.  I've tried;
PS3 Wireless Controller
Xbox 360 Wireless Controller
How long to does it take to recharge?
It should take the same amount of time as if it were plugged into a wall charger or any other device. To charge my phone from dead to 75% takes 90 minutes (same as a wall charger).
How much juice does it have?
Total power storage is about 2,500 milliamps. This is enough to charge my phone (which has a 1,300 mA battery) about 2 full times. An iPhone's battery is 1,200 mA, so you should about 2 charges, too. Smaller devices (like a shuffle) will recharge many, many times.
What batteries should I use?
You should only use rechargeable AA batteries (Nickel-Metal Hydride).  With 4 batteries, Mr. Buzz provides 4.8v-5.2v.
Do I have to use batteries?
Yes - the solar panel slowly trickle-charges your batteries, and they aren't large enough to directly power your USB device.
Mr. Buzz was designed by James Long at Lil' Brother SMT Assembly.  A kit or bare PCB are available at Gadget Gangster.
1-40 of 43Next »
mganpate says: Jul 31, 2012. 11:19 AM
interested pls share the pdf file on mahesh.gan.143@gmail.com
JeenJogi says: May 16, 2012. 2:20 PM
Commercial Solar Panels are Expensive!
Fact: It will take you more than 10 years to pay back
Solution: Using Surplus Solar Cells You can get pay back in 1-2 years
There is an Engineer from Chicago his name is John Sommer
He explain it All in his diy solar panels Blog Search for him using Google
Type "top diy solar panels" Open the first Result.
Note: Ignore the adds at the top.
susie says: Dec 10, 2009. 10:44 AM
This gives me cognitive dissonance. Seems like it should be something you can heat your coffee with...I don't totally get why you'd want a charger in a cup vs. it being packaged some other way. Am I missing something??
Putting it in your car cup holder wouldn't charge it...so that's not a reason for it to be in a cup.
Off the top of my head a solar charger that can screw onto a Gorilla tripod that I could clamp onto a roof rack while driving, clamp on a table near the window etc. would be something I might use.
tn. says: Jun 21, 2011. 6:39 PM
strange - when i read "charger in a coffee cup" i thought "wow - that'd be great at the office or on the go". i totally didn't get "gee - that's a lame idea", so thank you for that.
that being said, the whole point of this website is imagination - if you don't like the coffee cup, put it in an altoids tin or heck, an empty pasta box if you want.
Gadget Gangster (author) says: Dec 10, 2009. 12:04 PM
Ha!  It will NOT warm your coffee.
I put it in a cup because it was the first thing I thought of , but I use it on a window sill (and it works fine there).
But you can mount it on just about anything - a hat, directly on a window, or not even mount it at all - up to you.
monte the magnificent says: Oct 21, 2010. 2:30 PM
Quick Question: On the Gadget Gangster page it says the resistors have a 1/2 W limit but in this instructable it is listed at 1/4 W. Does it matter which one uses to build the charger? Thanks and great instructable.
Gadget Gangster (author) says: Oct 21, 2010. 2:50 PM
No, it doesn't matter. 1/4W (or smaller) is just fine.
Jr Hacking kid says: Dec 9, 2009. 1:46 PM
What if i want to use a bigger solar panel what voltage is needed to charge this upp and dose the kit come with everythin except the battery?
Gadget Gangster (author) says: Dec 9, 2009. 2:02 PM
Yes - Kit comes with everything but the batteries.
If you use a larger panel and it's also 6V, you'll be fine.  If you want to use a higher voltage panel, you'll need to add a regulator.
There's a space for it on the board, but the regulator isn't part of the kit.  You can use this one.
Jr Hacking kid says: May 31, 2010. 3:24 AM
The voltage regulator , You Have on your site Is this the one?
Gadget Gangster (author) says: Jun 1, 2010. 10:25 AM
Yep - same one.
Jr Hacking kid says: Jun 1, 2010. 5:17 PM
ohk XD
Yea i left this project for a while until i found it sitting on the side
Well its the summer time to finish my solar bag build
Jr Hacking kid says: Dec 10, 2009. 12:13 AM
oh ohk thank you that helped me out so where i put the jumper i place the regulator in there right?
xiaoyang88 says: Feb 26, 2010. 1:50 PM
 Hello nmcclana! I have been looking for the recommended LDO regulator, but there is no online retailer based in the UK. Mouser currently has the recommended regulator on back order. Could you please help me find another regulator? I have bought a MPT6-150 to replace the original panels. Also, if I want to put in a diode, where should I put it? Thank you for you help.
snotty says: Dec 11, 2009. 10:42 PM
All this project really needs is a diode to keep the batteries from draining through the panel when it's dark.
Of course this would drop the voltage a bit so we'd need a slightly higher voltage panel. Maybe a 6 volt panel like the Powerfilm MPT6-75 would work.
Who can recommend a panel and diode to perfect this elegant charger?
Jr Hacking kid says: Jan 12, 2010. 10:40 PM
hmm i placed a 1n4007 dioed
xiaoyang88 says: Feb 26, 2010. 1:13 PM
 Hello Jr Hacking kid, I want to place a diode to prevent the batteries from draining  as well. Can you tell me where i should place the diode on this circuit board? Thank you!!
Jr Hacking kid says: Feb 7, 2010. 9:32 PM
its been a month since i have this kit! And it works great but since my wires keep on breaking im going to upgrade it so right now it is not working and being upgraded ill be bck with more pics bye
Jr Hacking kid says: Jan 12, 2010. 8:50 PM
I got my Kit as a gift from My cousin My Kit was #238 And Here is some pics of my finished kit Ill up greade it some time soon To a 6v 200mAh solar cell and placed in my bag but i just placed it in a cup becuze why not follow the orginal first then make it unquic So here you go!!!
Jr Hacking kid says: Jan 6, 2010. 10:00 PM
hmm you should sell that
lDO Regulator Power 5V 800mA
part in the store product page too
XDleader555 says: Dec 25, 2009. 10:18 AM
The solar cells are not working... I can charge using the batteries though. Nice ible
Gadget Gangster (author) says: Dec 27, 2009. 1:00 AM
Thanks!
The solar panels won't charge anything by themselves (they only produce 50mAH @ 6V).  But they'll trickle charge your battery, so your battery can do the charging.
XDleader555 says: Dec 28, 2009. 10:27 PM
but there is no voltage when i put the solar film in the light and test it with a volt meter. I soldered the wires to it, what am i doing wrong?
Jr Hacking kid says: Dec 27, 2009. 1:16 AM
(removed by author or community request)
Gadget Gangster (author) says: Dec 27, 2009. 12:11 PM
I've updated the 'ible to reflect also using a regulator (this step, in particular).  I recommend using the MPT6-150, you can run them in parallel to get more mah, too - the regulator I recommend is more than enough - about 800mA.
Jr Hacking kid says: Dec 28, 2009. 12:54 AM
Ohh Yea i am sorry for deliting it idid it by accdent  cliked on it and didnt read it lol
But for thos who are wondering Wtf we are talking about  READ BELOW!
i think im going to get either two of these and solder them parallel so i get 200mah
POWERFILM,MPT6-150 rating at 6v and 100mah each
or
POWERFILM,P7.2-75 rating att 7.2v and 100mah
what do you think is better?
Jr Hacking kid says: Dec 28, 2009. 12:50 AM
Ohk Thank you verry much! XD
Ill be ording this some time soon!
Jr Hacking kid says: Dec 26, 2009. 11:27 PM
What size starbucks cup did you put it in?
Gadget Gangster (author) says: Dec 27, 2009. 12:57 AM
Venti?  The smallest one.  It would work in a bigger cup, of course.
snotty says: Dec 11, 2009. 10:38 PM
Nice simple project!
What are the capacitors for?
What do they do?
Jayefuu says: Dec 8, 2009. 2:21 AM
Ummm... In step 1 your talk about how much "juice" it has. You use milliamps to quantify the amount of charge it can store. Amps are a unit of current, do you mean ampere-hours? mAh?
PKM says: Dec 8, 2009. 6:46 AM
Further to what Jayefuu said:
Milliamps are not a measure of energy, they are a measure of current.
Neither are milliamp-hours a measure of energy, unless multiplied by a voltage.  I don't know if that's the ~6V AA pack or the 5V USB output.
You also can't compare milliamp-hours between different batteries with different voltages.  Your iPod battery is a lithium at 3.7V, for which 1200mAh is less energy than 1200mAh in your 4 AAs.
(Technically "power storage" is wrong as well, you store energy, but in this case it's obvious what you mean)
Please don't think I'm just criticising out of pedantry- it's because what you have written is incorrect and very ambiguous.  If it was just given out of interest it wouldn't be so bad but it's actually important for what you are building.  It's like giving dimensions for how to build something in feet instead of square feet- I could assume you mean square feet, but that isn't what you said and I might be wrong.
On top of this, I have seen people do completely the wrong calculation for LED resistors or battery capacities by using the wrong quantities, and coincidentally not blow anything up because they were in the right area.  I'd hate to wreck an iPod by trying to charge it with 1300 mA :)
CameronSS says: Dec 11, 2009. 6:11 AM
It's pretty close to a 5V AA pack, actually. These are NiMH batteries, not alkalines, so they're rated for 1.2V, not 1.5V. 4*1.2=4.8V, and slightly more when fully charged. It still needs clarification, but the total energy storage won't change a whole lot.
Gadget Gangster (author) says: Dec 8, 2009. 10:17 AM
You are correct, it is mA/h, and it's not meaningful unless the output voltage is also provided.  I do provide the output voltage in step 1 (the faq), it's 4.8v-5.2v.  In the intro, I was just trying to summarize. I was thinking most people would figure that a USB charger would provide USB-level voltage, but I specified it, just in case.  An iPod's internal battery is 3.7v, but the internal circuitry chargers it from the usb +5v.
MePerson says: Dec 10, 2009. 12:35 PM
 Now all you have to do is combine this and the Roof Coffee Cup
HEY YOU says: Dec 10, 2009. 4:43 AM
Nice Instructable!!
I thought it was a solar powered coffee cup
Cheers
grandtippler says: Dec 8, 2009. 1:56 PM
 Great idea, I need one of these.
lemonie says: Dec 8, 2009. 11:56 AM
Wouldn't the angle be better with the cup stood upside-down?
L
Gadget Gangster (author) says: Dec 8, 2009. 1:19 PM
I actually tested several different mounting types (Mounting on a cup is only one idea).
I didn't notice a significant performance difference when the cup was flipped upside down, and I like how the USB cable comes out of the cup spout.  It probably depends on the sun's position, ambient light, etc.
But it can be mounted to nearly anything, I tested a hat brim, backpack and a laptop bag.
lemonie says: Dec 8, 2009. 1:39 PM
Hat-brim? Now that's a good idea - mount a cooling-fan - summer-wear!
L
1-40 of 43Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
