Mudbloods Pamphlet
Published
Introduction: Mudbloods Pamphlet
Hey everyone! Here's a DIY for the Mudbloods and the Dangers They Pose pamphlet! Written by Dolores Umbridge and printed by the Ministry of Magic when Voldemort was in control during the Second Wizarding War. It's made up of 10 high resolution pages and a front and back cover. Most of the smaller text is in Latin, but the headlines are all in English. I hope you enjoy!
SUPPLIES
FREE TEMPLATES REMOVED BY REQUEST OF WARNER BROS.
Step 1: Printing
8.5x11 or A4 Instructions
Print the PDF double sided.
11x17 or A3 Instructions
Print the PDF double sided in landscape orientation. If the printer has a finisher attached, you can also select the folding and saddle stitched options.
Step 2: Stapling
Set aside the template page that is just the spine of the book. We'll get to that later. Next, make sure the pages are in order and staple them together where the Muggle Magic box is. Use paper clamps to make sure the pages stay aligned as you staple them.
You will want to saddle stitch the pages together, which means you'll stack them up and put two or three staples along where the spine of the book will be. Stack the templates (make sure they're in the right order - refer to the template files) and use paper clamps to hold them together. Set that aside and place a row of staple refills on your cutting mat. Use a thumb tack to remove two staples from the refill. Now, with your templates face down on the cutting mat, use one of the loose staples to mark where two staples should go along the spine (imagine a vertical line at the center of the template where the left and right pages meet). Use your tack to make holes where the staples would penetrate the template. Now feed the points of the staples through those holes. Flip the template over (make sure the staples don't fall out) and use your ruler to close the staples. And now all you need to do is fold the template and half.
Step 3: Cutting
Use your ruler and X-Acto knife to trim off all the white borders and the gray Muggle Magic box from around your templates.
Additional 8.5x11 or A4 Instructions
Cut out the Weasley & Weasley ad with your ruler and X-Acto knife. If you're using 8.5x11 or A4 templates, make sure you don't cut the staples off - we need those. Now cut out the template that is just the spine of the book and fold it in half vertically. Now use a glue stick to glue this on to the spine of your book in order to hide the staples.
Step 4: You're Finished!
That's it! You're all done!
Please let me know what you think and share your creations in the comments below! Thanks for viewing!
Follow me
YouTube: https://www.youtube.com/MuggleMagic
Twitter: https://twitter.com/MuggleMagicDIY
Facebook: https://www.facebook.com/MuggleMagicDIY
Instagram: https://www.instagram.com/MuggleMagicDIY
Pinterest: https://www.pinterest.com/MuggleMagicDIY
  • Stick It! Contest
    Stick It! Contest
  • BBQ Showdown Challenge
  • Backpack Challenge
    Backpack Challenge
