Muiltple Wiimote Mods All in One.
42,315
121
151
Posted
Introduction: Muiltple Wiimote Mods All in One.
Here we go again. But this time the mods are so easy I'm going to put three of them into one, Easy A button, Nunchuck LED, and The Player Indicator mod. I want to first state that none of these mods are done by me. The only mods done by me first are the Power and B button mods. Well why don't we get a move on?
Im going to do the mods starting with: the nunchuck mod, easy a button mod, and the player indicator mod.
They go by page.
Here is what all you mods will look like when they are done.
***Please note that this will void your warranty you have on the wiimote and nunchuck***
****I am not responsible for any damage you do****
Just say something if you need some help.
Step 1: Lets Get This Nunchuck Done.
OK, well here we go.
Items needed:
1 Tri-wing screw driver. (just google tri-wing to find one to buy)
1 LED color of your choice (3mm)
1 12v resistor (if you care about battery life)
1 nunchuck
1 15watt soldering iron
solder
electrical tape
First use your Tir-wing screw driver to unscrew the nunchuck. Force off the top as it has 2 clips that it connects to.
Second, bend your LED to look like picture one (the long leg of the LED is the positive ( + ) on and the short is the negative ( - ) . If you want to save battery power, cut some of a leg off and add a resistor to it. Place a piece of electrical tape on the nunchuck PCB board to avoid shorts.
Then you are going to solder the legs of the LED to the test points on the nunchuck that I have pointed out for you (if you have trouble with the small test points i have listed alternates). Plug the nunchuck into your wiimote to test it out.
If you get your light to well... light up, you've done it right. Put the guts of your nuchuck back into its body and screw it back in. And thats it!!!!
If you have any questions just ask, ill be happy to answer them.
Shall we move on to the Easy A button mod?
Step 2: Easy a Button
OK lets start with the A button. To follow this page I will list the steps in the order or the pictures.
List
1 wiimote
solder
Electrical tape
First remove the screws from the wiimote. You'll notice that the wiimote won't open easy around the top and this is a real problem area for everyone, even me. The best think you can do is try to pull the case up as far as you can and put a butter knife uner the top and push down toward the bottom. If you break a peg off don't worry about it, when you done modding the wiimote just put a dab of superglue on the side and it'll hold fine.
Secondly bend your LED to look something like mine. Then your going to want to fit the LED around wiimote's PCB like image #3, once you have it aligned facing the a button solder it down. *remember what legs on the LED are Positive and Negative* (images 2 and 4 are not mine, taken form www.wiimotemods.com)
Test if you did it right by putting the PCB back in the bottom case of the wiimote and put some batterys in and push a button. If your light lights up... well you get the picture.
Next you need to break off a tab that will block your LED from fitting inside your wiimote. Look to images 5 and see for help. Put down electrical tape so the LED doesn't shine through the wiimote's case.
If its working you should see something like image #8.
Trouble shooting.
If you hit a button and your Player indicator lights come on but led doesn't.
check led connection.
Batterys are in but nothing is working.
You have most likely blown a fuse inside the wiimote.
How to fix this
First take some tweezers and look by your One and Two, there will be a little fuse with the letters F1 by it. Put your tweezer on the 2 outside points and press a button. Once your lights come on take wire and bridge the connection like i did.
Please ask for help if you need me to explain something further.
Step 3: Player Indicator Mod
This mod is easy but very hard all at the same time. You'll see what I mean.
I have a shortage of pictures for this mod as i can't do a new one so i have to use the one i have already done as a reference. I will do my best to set you on your way.
list :
1 Wiimote
4 SMD LEDs (0603)
Tri-wing screwdriver
Soldering iron with solder
Magnifier glass (if you have trouble looking at small items)
Desoldering Braid
Tweezers
First take apart your wiimote. Then locate your player indicator leds at the bottom of the wiimote. If you have trouble finding them put some batterys in the wiimote and press home, you'll find them trust me.
Secondly take your desoldering braid and desolder leds 2-4. (if your worried you might not be able to do this mod remove player's 4 led and try to installed your smd led on it)
Once you get them desoldered take out your smd leds. To put the leds on put some solder on your iron (tiny bit!) and place your iron onto one side of the pad and use the tweezers to slide your new led into place. To find out what side is pos and neg of the leds is beyond me, so just do some testing and your get it. It might take some time to do this mod, just make sure not to get mad and don't burn your pads.
Ask for any help if needed.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
154 Comments
Do you know how to remotely wire a switch to operate the B (trigger button?)
Just find the power and ground points for the B button, and solder the wires of your new switch to them. All the buttons do is complete a normally open circuit. Think of it like a drawbridge, when you push B, you're lowering the bridge and the cars (electricity) can get through. By wiring another button there, you're basically installing another drawbridge alongside the first one. Whichever bridge lowers, the cars are going to drive across. Same thing here.
Can I use smd 0603 leds for the a button and the nunchuck mod?
You can but I will urge against this because it will be more trouble then its worth trying to attach wires to the SMD and then isolate it so it doesnt short against the PCB (since the SMD contact are on its surface). I have tried doing something like that before and it was just to much effort and would never be reliable. If you want something lower profile then the 3MM led then buy some flat leds. If youre worried about price of 3mm leds dont be, they are very very cheap.
If I don't put a resistor, how fast do the batteries burn? (Nunchuck Mod)
The resistor is mainly to help the LED not have to much voltage going to it causing it to burn out. The voltage on the nunchuck is 5v (if I remember right) and LEDs are usually 3v. So not using a resistor will not affect the battery in noticeable way.
Anything above 10k 1/4watt would be fine. Here is a link to some 10k ones- http://www.amazon.com/E-Projects-10k-Resistors-Watt-Pieces/dp/B00BWYS9BA/ref=sr_1_5?s=industrial&ie=UTF8&qid=1436792916&sr=1-5&keywords=resistor
However you only get 5 of them. Here is a link for 800 for 7$ more with various types (far better deal)- http://www.amazon.com/E-Projects-800-Piece-Value-Resistor/dp/B00PKCVCL4/ref=sr_1_17?s=industrial&ie=UTF8&qid=1436792916&sr=1-17-spons&keywords=resistor
Thanks for replying! and what kind of resistor should I use? I'm fairly new to this stuff and I don't know which kind.
