3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Muiltple Wiimote mods all in One.
Here we go again. But this time the mods are so easy I'm going to put three of them into one, Easy A button, Nunchuck LED, and The Player Indicator mod. I want to first state that none of these mods are done by me. The only mods done by me first are the Power and B button mods. Well why don't we get a move on?
Im going to do the mods starting with: the nunchuck mod, easy a button mod, and the player indicator mod.
They go by page.
Here is what all you mods will look like when they are done.
***Please note that this will void your warranty you have on the wiimote and nunchuck***
****I am not responsible for any damage you do****
Just say something if you need some help.
Step 1Lets get this Nunchuck done.
OK, well here we go.
Items needed:
1 Tri-wing screw driver. (just google tri-wing to find one to buy)
1 LED color of your choice (3mm)
1 12v resistor (if you care about battery life)
1 nunchuck
1 15watt soldering iron
solder
electrical tape
First use your Tir-wing screw driver to unscrew the nunchuck. Force off the top as it has 2 clips that it connects to.
Second, bend your LED to look like picture one (the long leg of the LED is the positive ( + ) on and the short is the negative ( - ) . If you want to save battery power, cut some of a leg off and add a resistor to it. Place a piece of electrical tape on the nunchuck PCB board to avoid shorts.
Then you are going to solder the legs of the LED to the test points on the nunchuck that I have pointed out for you (if you have trouble with the small test points i have listed alternates). Plug the nunchuck into your wiimote to test it out.
If you get your light to well... light up, you've done it right. Put the guts of your nuchuck back into its body and screw it back in. And thats it!!!!
If you have any questions just ask, ill be happy to answer them.
Shall we move on to the Easy A button mod?
147 comments
1-40 of 147next »
Jan 14, 2009. 9:56 AMR3dfaction says:
I'm surprised no one has noticed yet but the only controllers that work for the "A" button mod are the ones that came with wiiplay or if u bought it from store not the one that came with the console.
Check the link below
http://www.wiimotemods.com/?p=6
Jan 1, 2012. 2:05 PMben_xman says:
Would love to use this but the site's images have been removed. Update link?
Jun 28, 2010. 5:42 PM89daviddd says:
:( ur nunchuck is not made the same way as mine mine doesnt have the positive and negative at the same place
Jul 17, 2011. 2:32 PMThe Nate Dawg says:
Mine was also different, but I figured it out. Look at where the wires come to the board. The red on one side is 3v and the black is ground. Wire it up in series with a 100 ohm resistor to get ~28ma.
May 7, 2010. 1:38 PMfastfilmsinc says:
it would be awesome if you could have color changing leds, is that even possible
May 29, 2011. 10:00 AMElectroinnovation says:
If you want to do that just get some leds from here. Theyr'e pretty cheap but they do come from china usually so it takes 2-3 weeks to ship. Make sure you get some with 2 leads because the ones with 4 leads have each color control individual (Red, green, and blue) then a common anode or cathode. Using the 2 lead leds are just easier for something like this.
May 28, 2011. 6:56 PMThe nerdling says:
i have two types of colour changing leds
one where it just has two pins but you reverse the polarity of the terminals so +is - and - is +
and a nother one with 3 pins and the middle is - and each of the outside pins are + fo each colour
Jul 29, 2010. 10:57 PMzack247 says:
yep! i see leds smaller than the one he used for the button mods in those solar color changing globes. they change color on their own, so its pretty cool to do
Jul 6, 2009. 2:03 PMmaster_of_instructables says:
OMF!!! i only fried my wiimote and nunchuk
May 28, 2011. 6:57 PMThe nerdling says:
nice idea
Oct 11, 2010. 5:22 AMElectroinnovation says:
Very Great idea! I just have one question. How many volts are going into the nunchuck and wii remote at the points you connected to? I want to find out what kind of resistors I'm going to need.
May 28, 2011. 6:53 PMThe nerdling says:
if it's 5 volts i would use a 240& resistor
Dec 10, 2010. 12:01 PMElectroinnovation says:
Okay thanks
Mar 7, 2011. 10:29 AMmaxthrottle says:
Do you know how to remotely wire a switch to operate the B (trigger button?)
Jan 24, 2011. 6:26 AMhassiimperatoretorres says:
can you do the same think but in a play station control?
Aug 4, 2010. 12:46 PMlegoman2300 says:
wiimote master I have tried to mod my nunchuck and have failed constantly I will pay you $30 10 dollars a mod I will also pay for shipping if you accept please email me at kenz.lee123@yahoo.com
Aug 8, 2010. 12:50 PMraykholo says:
Was the fuse issue related to the smd leds?
Mar 16, 2009. 10:44 AMRiddleOfSphinx says:
So there's absolutely no way to do this if I have the remote that came with the console :-S ? I see that there is a "+" and "-" by where the vibration motor is connected, but wasn't sure if that would make the led turn on constant or not 8-} If anybody knows how to do this with the remote that came with the console, please reply.
Mar 16, 2009. 9:20 PMRiddleOfSphinx says:
Oh, I know it'll flash and what not when you hook it up to the plus and mius. I just didn't know what contacts to solder to since it's a different remote. So, yeah, if you could I'd appreciate it if you could show me :)
May 30, 2009. 11:00 AMlllalllo says:
Try connecting the LED through a rectifier, so it doesn't flash but stays on during the vibration.
Aug 3, 2010. 3:50 PMraykholo says:
If the vibration is triggered in bursts, then a capacitor is what you need, in parallel with the LED.
Feb 11, 2009. 10:37 AMMisterAlex says:
Man, this is great. You don't happen to live in the Dallas area, do you? I'd pay to have someone mod my controllers for me (hardly any soldering experience). I may give it a shot anyway, though.
Jun 7, 2009. 7:10 AMcrazyhalofreak says:
where in MO? around central?
Feb 27, 2010. 3:43 PMcrazyhalofreak says:
dang
Nov 8, 2009. 11:28 AMPikminRed says:
Eeee Bay!!! Id buy one.
Oct 15, 2009. 6:35 PMbaconmaster says:
By the looks of it the resistor colours are green,blue, brown and goldso i think its 560ohms +/- 5% and i reckon 1/4 watt. If thats the samenunchuck used throughout the process (which im pretty sure it is) thatresistor should work. if this has already been posted im sorry
Jul 28, 2009. 12:02 PMjaahas says:
its that led a 15-30 mcd or more?
Jul 7, 2009. 3:15 PMmaster_of_instructables says:
oo thanks i gonna try
Jul 3, 2009. 11:53 AMgoeon says:
the led is flashing what do i do
Jul 3, 2009. 11:54 AMgoeon says:
on the a button
Jul 3, 2009. 12:02 PMgoeon says:
nvm fixed it
Apr 11, 2009. 7:56 AMRazorChrist says:
I just wanted to say thanks for the awesome easy guides! I finally finished putting in the flashing Tri-color LED into my nunchuck. Had a problem with the thumbstick pushing down on the LED, causing it to short and turn off, but fixed that by filing down the outside edge of the LED. Made a video of it to show off, so here it is:
http://smg.photobucket.com/albums/v103/bratprince/WiiDev/?action=view&current=Wii_Nunchuck_Mod.flv
P.S. Random shorts suck...lol.
Mar 23, 2009. 8:02 AMfriction_addiction says:
hi thanks for this guide, iv used it too light up one of my mote and it looks great, but my other mote differs from my first one, do u have a pic of the solder points for the differnet version of mote? thanks
1-40 of 147next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:Wiimote Master
