3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Muiltple Wiimote mods all in One.
Step 2Easy A button
Easy A button
  • last photo ←
OK lets start with the A button. To follow this page I will list the steps in the order or the pictures.
List
1 Tri-wing screw driver. (just google tri-wing to find one to buy)
1 LED color of your choice
1 wiimote
1 15watt soldering iron
solder
Electrical tape
First remove the screws from the wiimote. You'll notice that the wiimote won't open easy around the top and this is a real problem area for everyone, even me. The best think you can do is try to pull the case up as far as you can and put a butter knife uner the top and push down toward the bottom. If you break a peg off don't worry about it, when you done modding the wiimote just put a dab of superglue on the side and it'll hold fine.
Secondly bend your LED to look something like mine. Then your going to want to fit the LED around wiimote's PCB like image #3, once you have it aligned facing the a button solder it down. *remember what legs on the LED are Positive and Negative* (images 2 and 4 are not mine, taken form www.wiimotemods.com)
Test if you did it right by putting the PCB back in the bottom case of the wiimote and put some batterys in and push a button. If your light lights up... well you get the picture.
Next you need to break off a tab that will block your LED from fitting inside your wiimote. Look to images 5 and see for help. Put down electrical tape so the LED doesn't shine through the wiimote's case.
If its working you should see something like image #8.
Trouble shooting.
If you hit a button and your Player indicator lights come on but led doesn't.
check led connection.
Batterys are in but nothing is working.
You have most likely blown a fuse inside the wiimote.
How to fix this
First take some tweezers and look by your One and Two, there will be a little fuse with the letters F1 by it. Put your tweezer on the 2 outside points and press a button. Once your lights come on take wire and bridge the connection like i did.
Please ask for help if you need me to explain something further.
25 comments
Jan 14, 2009. 9:56 AMR3dfaction says:
I'm surprised no one has noticed yet but the only controllers that work for the "A" button mod are the ones that came with wiiplay or if u bought it from store not the one that came with the console.
Check the link below
http://www.wiimotemods.com/?p=6
Jan 1, 2012. 2:05 PMben_xman says:
Would love to use this but the site's images have been removed. Update link?
Jan 24, 2011. 6:26 AMhassiimperatoretorres says:
can you do the same think but in a play station control?
Mar 16, 2009. 10:44 AMRiddleOfSphinx says:
So there's absolutely no way to do this if I have the remote that came with the console :-S ? I see that there is a "+" and "-" by where the vibration motor is connected, but wasn't sure if that would make the led turn on constant or not 8-} If anybody knows how to do this with the remote that came with the console, please reply.
Mar 16, 2009. 9:20 PMRiddleOfSphinx says:
Oh, I know it'll flash and what not when you hook it up to the plus and mius. I just didn't know what contacts to solder to since it's a different remote. So, yeah, if you could I'd appreciate it if you could show me :)
May 30, 2009. 11:00 AMlllalllo says:
Try connecting the LED through a rectifier, so it doesn't flash but stays on during the vibration.
Aug 3, 2010. 3:50 PMraykholo says:
If the vibration is triggered in bursts, then a capacitor is what you need, in parallel with the LED.
Mar 23, 2009. 8:02 AMfriction_addiction says:
hi thanks for this guide, iv used it too light up one of my mote and it looks great, but my other mote differs from my first one, do u have a pic of the solder points for the differnet version of mote? thanks
Mar 3, 2009. 2:28 PMmayday295 says:
When he says you might blow a fuse , he means you are guarenteed to blow a fuse, and even when you fix it it might not work. ( i blew a fuse, fixed it, and then when i tried it again the controller wouldnt work (the light would) until i disconnected the led.
Nov 9, 2008. 8:55 PMjester070993 says:
where do you put the resistor?
Nov 30, 2008. 8:08 PMjester070993 says:
for the nunchuck, and do you just solder the led to the led or how do you get it to stay on the led
Oct 2, 2008. 2:06 PMryzzey says:
i did these mods and they worked fine, only thing is you need to add a resisitor as batteries will run out quicker otherwise. Great Mods, thanks :D
Apr 27, 2008. 6:38 PMsiedpe13 says:
fuses blow for a reason, so is it safe to do
Aug 3, 2008. 12:56 PMpoiuyt55 says:
When i press a button nothing happens and then i tried the fuse thing and it still dosn't work.WHAT NOW????
Sep 20, 2008. 3:58 PMultimatesx9 says:
or the big capacitor broke on the bottom, like one of mine....... but not by me, by the bloody bateries that were in it, they leaked...... :¦
Apr 29, 2008. 9:19 PMsiedpe13 says:
what about putting a resistor
May 2, 2008. 6:27 PMsiedpe13 says:
Do you know anything about electricity, first resistors don't resist power flow, they dissipate power. What resistors mainly do is reduce current flow, and saying power flow doesn't even make sense. You are right about the fuse being used to protect but they're there for protecting against shorts, other wise an excessive amount of current. If you were trying to say the resistor will oppose the current, and the fuse is there to protect against a short, it still would make sense. The only reason a fuse is needed is to protect the circuit if there is an excessive amount of current and it blows instead of melting the wires. How a short (or short circuit) works is when current finds a easier way through the circuit( meaning no resistance) the power source can dump 100% of its current through the wire there by melting it, and is why fuses are used. So actual you could say a resistor is there to protect against circuit destruction even though the resistors purpose is to resist current flow, and a fuse is just a wire that melts under specified circumstances. I was just wondering if putting a resistor to make sure there isn't an overload of current though the newly created circuit, after seeing that you "fixed" your fuse by skipping it with a wire. i Don't know if you interpreted my previous question wrong but putting a resistor in series with the led would seem to protect the circuit from even needing to use the fuse, because when you have a blown fuse, something IS wrong.
May 30, 2008. 1:29 PMZephron says:
Help! That tiny tab you show in picture 3, it fell off. I totally forgot where it was supposed to go... is it important? Please tell me where it goes xO.
May 1, 2008. 3:10 AMcraig3 says:
where did you put the led? because i tried to put it there it looks like you have it but the case wont close afterwards
Mar 31, 2008. 2:30 PMandrew1234 says:
where do u get those led s
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:Wiimote Master
